Question about Brother DCP-110C All-In-One InkJet Printer
DOCUMENTS PRINT IN FADED GREEN OR FADED BLACK
  • 526 Answers
Do a test print and check to see if the nozzles are firing properly and the colors are correct. if you are using generic ink that could be an issue.
do a couple cleanings and then another nozzle check to see if it has improved.
if you replace the ink cartridge, remember that it will take time for the new ink to creep into the printhead system.
Posted on Sep 02, 2010
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
The Black prints faint on the left side of the page for our HP2605dn printer.
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
Jun 08, 2010 | HP LaserJet 2605DTN Color Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Faded black print.
may have gotten a bad cartridge ! try another one !!
Jul 21, 2009 | Samsung CLP 300 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
My Kodak 5300 is printing faded and unclear documents
You need to call Kodak to get a new print head.
I am on my 3rd print head since 12/07 when i bought it new.
They will send you a FREE replacement head.
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Faded or no printing of documents
First, have you removed the protective tape from the bottom of the printer cartridge? I know it sounds simple, but it's something easy to overlook when you install a new cartridge.
Jun 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black ink looks faded!
Providing that the ink cartridges were new and supplied with the printer, the cartridge is defective. I also don't think that you used up all the ink either unless you printed hundreds of documents already. Take the cartridge back to the store where you got the printer from and they should give you a new one.
Oct 29, 2007 | Dell 810 All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
