Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I have F1 flashing on my dish drawer....turn it off a couple of months ago because of the same issue and have not used it since....turned it back on and used the bottom drawer...all OK...went to use the top drawer again and the F1 returned??? please help
  • Fisher and P... Master
  • 3,247 Answers
Please confirm if the F1 on top drawer shows up immediately you press the Start button or part through a wash cycle? What happens when you turn off the power and back on.
Posted on Sep 03, 2010
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
F1 shows on control panel of both drawers,after a couple of startup.Even when machine is not being used both drawers startup on F1,only way to control is to shut off at main supply
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 17, 2010 | Fisher and Paykel DD605SS Stainless Steel...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did...
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher problem
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
127 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
