Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication
to establish Internet connection for end-users. MAC address is a unique
identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone
feature of the router. MAC Cloning is a procedure which enables a
router to copy the MAC address of the computer that's registered with
the ISP.
To setup a Linksys router with Cable connection you need to perform
four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
To configure the wireless router and the laptop's wireless card, follow these steps : - 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL 3. Enter the router setup, login and password 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WPA2 (if not then WPA). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
hi! sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection. also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
If you cannot find any wireless driver on your Win XP then you do not have a wireless connection on this computer...Most commond problem if you have a built-in wireless adapter, the wireless switch is turn off, you can turn it on by switch the on-off panel on the side of the laptop or for some you need to press a key combination. (i.e. Fn+F2)
