Question about Nordic Track NordicTrack Treadmill, A2550
My Nordictrack A2050 only speeds up when I hit the "7" button. All other speed buttons get no response and only the speed down (not speed up) buttons work. To walk or run I have to hit "7" and then speed down to where I want to be. Also, the button for the fan and the programmed workouts give no response. Help!
FrogCatcher
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
Posted on Nov 18, 2009
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: Hi, I have a NordicTrack Treadmill, A2050. When
Unplug unit then remove motor shroud then plug unit in then start treadmill your going to use a flat tip screw driver as a stethoscope. Now place the flat on the motor at edge close to the flywheel put your on the handle your ear and you should be able hear if the loud noise form the bearing if not, then repeat procedure on the other end by the fan if the noise is pin pointed on the motor then replace motor, if not originating from the motor the proceed to the front roller.
Use a flash light and observe and locate the font roller shaft so that you can comfortably rest the tip without it slipping on either end of roller.
As before repeat the procedure that was performed on the motor if noise originated their then replace roller if not proceed to rear roller.
Use you flash light and look the adjusting bolts where the end caps are the proceed to insert the screw driver and make contact with the tension bolts listen to each side.
You should locate noise with this procedure take your time and be careful
Posted on May 17, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack A2050 Treadmill...
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
How do you recalibrate A2050 incline
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 06, 2011 | Nordic Track NordicTrack Treadmill, A2550
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
When i power my Nordic Trac A2050 on it powers up but when I press the speed button or incline button is beeps twice but does not reponse to the command
This sounds like a bad controller. If the machine is under warranty contact the warranty provider. The controller is not hard to replace if you are electrically inclined but it does require calibrating.
Jun 14, 2010 | Nordic Track NordicTrack Treadmill, A2550
Good Luck! Tim
Dec 15, 2009 | Nordic Track Exercise & Fitness
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track NordicTrack Treadmill, A2550 Logo
102 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
