Question about Kenmore 72187 Air Conditioner
Unit is several years old but only used a few times. This summer we used it from July to present but it's cooling ability has declined steadily since early August. We use it durring the evening from 6pm to 6am. Not durring the day. I cleaned the filter, but it still does not get as cold as it use to. Suggestions?
  • 284 Answers
Potentially could be low on refrigerant (freon) and no access taps are available to check freon pressures,so you would have to call a reputable hvac company to add taps to check freon pressures and if low add charge and look for a leak? Ideally would be to install permanent access valves after recovering freon charge and weigh in required factory nameplate amount.
Probably costly and maybe time for a new one vs. repair? Be sure your coil behind the air filter is clean? and be sure the coil outside is clean?You could take the unit outside and clean both coils with a garden hose but be careful not to over pressurize the coils because the fins bend easy,use an up and down motion not side to side.Let unit drain and reinstall and try
Posted on Sep 02, 2010
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
I installed a fujitsu asu24c1 unit in my garage a few years ago. I used it for one summer, didn't turn it on last summer and when I turned it on this year it wouldn't cool. I have troubleshooted...
With the limited information i would suggest the following:
Check to see if the outdoor unit is running.
If the outdoor unit is running, grab the large copper line coming out of it and see if it is cool.
If the fan outside is running and the line is not cool then the compressor is not running or the system has lost its refrigerant charge.
Check these things and repost for a more complete answer.
Hope this helps.
Sep 05, 2011 | Heating & Cooling
My nc10 is not charging, but works when plugged in
This usually indicates a problem with the laptop's battery.
How old is your battery? More than three years?
Did you notice a considerable decline in unplugged time(the time you work on battery without being connected to mains supply) before it stopped working?
If the battery is too old or if you noticed a severe decline in unplugged time, get a battery.
If anything else, it needs to be check by a professional.
Mar 03, 2011 | Samsung NC10-14GW Notebook
No cool air coming out of home air conditioner
Unless your compressor is burnt up, you probably don't need a new unit. If it's a 1998 it's not that old and you can get parts, the only thing is it's probably R-22 refrigerant and they must fix the leak in the unit if that's the problem before adding refrigerant and the refrigerant is expensive.. All they have in a heating and cooling system, that needs replaced, are a few parts. Outdoor unit has a fan motor,compressor, capacitors fan and compressor and a contactor. Furnace has a blower motor, capacitor, gas valve, fan and limit or furnace control board, which they still make replacement parts for.
My advice would be to call some more HVAC companies, till you find one, that is willing to fix your unit and not replace it..
May 31, 2010 | Whirlwind FH-778 Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Noisy unit,it makes pumping noise thru the whole house.
you have already used it for 10 years, now please buy the new one and give kenmore little rest!!! whatsay?
May 18, 2009 | Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
No heating, cooling or fan.
I'm confused. You have a Trane, but are asking about the Goodman warranty. I missed something there I'm sure, sorry.
"IF" Trane has a recall or warranty issue, then any qualified technician should be able to help you with that. The parts would be provided by trane in such an event, but unless the unit is less than 1 year old, chances are you will have to pay for the labor.
Being an electricain help if you want us to assist you in troubleshooting.
This link takes you to the TRANE contact page. They can answer any warranty/recall questions you have.
Jan 21, 2009 | Heating & Cooling
LG LWHD1800R air conditioner problem
It sounds to me like the compressor is overheating and tripping on internal or external overloads. After the unit cools down again it will try to run for a little while. Then this cycle would start over. I would check the condenser coil for dirt and filth. This portion of the unit may be on the out and backside of the unit. You should at least be able to see light through the coil.
I believe the thermistor that you removed temporarily is used for a freeze situation. I do not believe that it is your problem. Good luck:)
May 17, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Kenmore 72187 Air Conditioner Logo
147 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
