Question about Intex Easy Set Pool 15x36
I have an above ground intex vinyl pool, does this need to be emptied and removed in the winter?
  • Intex Master
  • 8,404 Answers
Where you live and the severity of your winter would dictate the answer here and you have said nothing regarding this. Please contact a pool service company in youre area and ask for their recommendations.
Posted on Sep 26, 2010
Do I have to empty my pool to replace the side supports on an intex above ground pool
they keep the wall up. so, I would suggest to empty the pool.
Mar 08, 2015 | Intex Pool & Spa
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
WHAT AND HOW DO YOU VACUUM INTEX ABOVE GROUND SALT WATER POOL
I used the manual vacuum that came with the pool during the summer because I actually got in the pool and vacuumed), but ultimately, now that it is cold, I went to the pool store and bought a much bigger vacuum (that still hooks up to the water hose) and then a longer pole. It's just too darn cold to get in the water during the winter. :-) Hope this helps!
Nov 02, 2012 | Intex Automatic Salt Water System for ...
How do I winterize my krystal clear sand filter pump
The manual might provide some insight but usually the Intex pools are vinyl and are taken down and stored indoors for the winter. This makes a lot of sense in most areas because they won't be used in the winter and if you kept it set up the sun, wind, and temperature affects the plastics, etc. so that its lifespan is reduced. If it is stored in a place that freezes then you would need to make double sure there is no water in the equipment.
I hope this helps.
Sep 18, 2011 | Intex Krystal Clear Model 635 Pool Filter...
We got a above ground salt water pool an it's turning a little green what would be the best thing to put in it.
The first thing to do is to shock it with vinyl to about 10 ppm. This should start the progress to blue. Follow the Intex instructions to make sure the pool contains the correct amount of salt and stabilizer. The pump, filter and chlorinator should be run continuously until the water has clarified. The chlorine should then be kept between 2 and 4 ppm. One last suggestion, the filter gets plugged more quickly when you have shocked the pool to get rid of algae so make sure you clean the filter to keep the flow up. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
Is there any chemicals I need to add to my pool when I leave it up and full of water for the winter. I am worried about the alge growth. when I stop treating the water . on my salt water system.
If you have the intex soft side pool do not leave it up.
Once the water freezes and thaws you take a big risk of gouging the pool and thus tearing it.
These pools are meant to be taken down every year if you live in a freeze area
Aug 23, 2010 | Intex Automatic Salt Water System for ...
Would like to know how to close a salt water pool for winter
There is nothing special about closing a pool based on using a salt water generator system. You can use any chlorine based chemicals for your winter dosing and you drain the lines, including the generating cell, just as you always would.
Oct 09, 2009 | Intex Automatic Salt Water System for ...
We are taking down our intex pool for the winter are there any special instructions?
Store is some where that is above 50 degrees, when the vinyl gets too cold it becomes brittle and can shrink/crack. Also make sure no bugs or rodents can get at it! They love to make 'homes' in between the creases in the winter months.
Sep 04, 2009 | Pool & Spa
Intex Easy Set Pool 15x36 Logo
200 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
