Question about Cameras
Camera wont turn on batteries are fine is there a way to reset
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
My samsung nx11 wont turn on. How do I reset it without turning it on?
Don't know if it needs to be serviced or you are having a battery problem. is the battery charging ? is the battery a year or two old and needs to be replaced ?
Jan 24, 2013 | Samsung NX11 Digital Camera
My samsung promising photographer L83T won't turn on, it's fully charged and i have replaced the battery. It worked fine after i replaced the battery but when i recharged it it now wont turn on or do...
suspect that the battery may have been incorrectly charged and may be damaged.
suspect charger is not charging the battery properly.
try any reset that that camera may have.
Nov 13, 2009 | Samsung L83T Digital Camera
My dsc-85 wont power down. I turn it off it comes right back on?Everything else is normal Thanks
remove the battery. wait about 20 minutes. reinsert the battery and that will reset it and you should work fine
Sep 09, 2009 | Sony Cameras
Camer wont turn on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jun 30, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens wont come out
Try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persits after Power Resetting the Camera service of the Camera is recommended.
Jun 15, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Camera wont turn on My Nikon D40x wont turn on at all, i have been using it, then plugged it in the my laptop with the USB cable, unplugged it to take more pix, and it now wont turn on at all!!
Just a suggestion ... remove the lens, card and battery. Recharge the battery completely. Install the lens, card and battery then do a hard reset...
Hard Reset:
With D40 you need to install the lens, the card and the battery then open the cover under which USB and video sockets are. There is a small button in the hole. Press it with pencil tip or something and the camera will be reset losing all settings and clock time.
May 28, 2009 | Nikon D40x Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
HP Photosmart 945 Digital... Problem
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Polaroid A700 digital camera
my batteries are good but the camera just wont turn on at all
Jan 30, 2008 | Polaroid a300 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
