Question about Dell DimensionTM E520 PC Desktop
Dell E520 case
Just wanted to know how to take the case completely apart.
Not just take the side cover off..
Would it be best to just take the entire computer apart..
Ie. Mobo, hdd, drives, heatsink, power supply ect so im left with an empty case?
  • S_C_S May 10, 2008
    Have been redirected to that place/link a few times.. im not trying to install or remove parts I'm trying to remove panels so i can paint them.
    Brigadier General:
  • 6,966 Answers
The Dell E520 Service Manual details how to remove and i stall all the components/parts of the said computer. It may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 10, 2008
  • Louie  Role
    Louie Role May 10, 2008
    Hmmm, the link did no work. Let's try that again.....
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Orange light
If its a Dell E520
You can tell a lot about the condition of your Dell E520 computer simply by looking at the lights on the front of the unit. The color and condition of those lights can indicate a problem with the computer's hard drive, monitor and other components. Learning to read these lights and understand what they mean can save you a lot of time and make troubleshooting a lot easier and more effective.
Unplug the Dell E520 and plug it back in. If the amber light stays on, try moving it to a different power outlet and using a different power cord. Remove all peripheral devices from the E520, with the exception of the keyboard and mouse. A steady, amber power light can be caused by a malfunctioning piece of equipment. Turn on the computer on and wait for it to boot. If the computer boots with the peripherals removed, add back each peripheral one at a time, rebooting the computer after each device is added. Continue this process until you identify the malfunctioning device. Shut down the Dell E520 and remove all devices from the back. Remove the retaining screws on the back of the tower and remove the computer case. Locate the memory modules on the motherboard and remove them one at a time. You should see small, white retaining clips on the motherboard these retaining clips hold the memory in place. Spread those clips apart, then lift up the memory module and set it aside. Remove all the memory modules, then add them back one at a time, restarting the computer after each one is added. Continue until you identify the malfunctioning memory, then replace it with a new module. Remove any add-on cards for graphics controllers, networking and other purposes. Remove all the cards, then reinsert the cards one at a time until you find the bad card.
Feb 13, 2013 | Dell Inspiron Computers & Internet
I have a dell 8200 and want to take that info to the dell e520 hard drive is there a way to piggy back the two hard drives together so i can tranfer files to the e520 or can I at least copy some file
Hi ,
yes you can open your case and there should be two ide cables , one to your harddrive the 2nd to your cdrom/dvd player , diconnect the cdrom drive and use the cable to go into your 2nd harddrive , copy all you want , then just reinstall the cd drive and your good to go ............you might have to go into your setup or cmos and have the harddrive detected ......................Good luck Roy
Nov 09, 2011 | Dell Dimension E520 PC Desktop
The speaker wheel on the volume control seems to skip and adjust irregularly. Can I spray or take apart to clean?
You are most kind, thank you.
'Like the monkey looking at the monolith in 2001'.
NOW that's PRICELESS!
I almost bl-ew jets of Mountain Dew!
I can see that you have determined, that I wasn't referring to EMPTYING the can of electronic cleaner towards the volume wheel. As apparently my esteemed colleague seems to think.
Just tiny short bursts.
Short burst, rotate the wheel, short burst, rotate the wheel.
No, it is my opinion that you are very intelligent, and the speaker case design is one of those that is sealed from the factory.
Could be mistaken about the design.
There may not be enough information out there, that details the construction good enough for me to determine if you can open it. Do you have the manufacturer name, and possibly the model number? Usually on the back.
Jan 23, 2010 | Dell Dimension E520 PC Desktop
Dell E520.Outlook Express
taking the backup of your outlook and reinstall the window.
Jan 19, 2010 | Dell Dimension E520 PC Desktop
My rewriter is broken drawer ha been snapped off
This is Dell Support>Dell Dimension E520 Desktop PC>Service Manual,
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/index.htm
I invite you to left-click on - Specifications
Scroll down to the heading - Drives
Available devices - 4 Serial ATA drives - CD/DVD drive.
Serial ATA. Looks kind of confusing, huh?
= SATA
IDE has been changed to PATA.
(Integrated Drive Electronics)
It has been felt that there would be less confusion this way.
PATA = Parallel ATA
SATA = Serial ATA
http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
The Dell Dimension E520 Desktop PC comes with a dual layer DVD burner, and a DVD drive.
(DVD burner will have DVD-R/W or R/RW on the front usually)
You need a SATA DVD R/RW drive.
Myself I use Lite-On optical drives.
Why?
Cheap in price, high in quality. I have one I have been using for over 3 years, with no problems. Price was around $35 US.
Not advertising for Lite-On.
It's a dual layer, DVD combo drive. Burns CD's, and DVD's. Has the HP LightScribe technology. If I use the HP disks for LightScribe, I can make labels for the disks, or burn a label right on the middle of the disk itself.
TIP: Everyone looks for a f-a-s-t burner! The Lite-On I have is Fast. You Do Not want to burn disks in a fast mode.
Better quality of copying, or recording is done at a slower speed.
Should your optical drive not come with burner software, I recommend Infra Recorder.
It's Free, and works Very well.
(I like it better than Nero)
1) Computer unplugged from power
2) Open the computer case side panel (Side panel release latch is on top, at the rear. In the Service Manua,l you can click on Removing and Installing Parts. Scroll down to Removing the Computer Cover)
3) TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Your body carries Static. Static will fry out computer hardware components. Computer unplugged from power you are safe. TOUCH the metal frame, your computer is safe)
4) Removing and replacing an optical drive.
In Removing and Replacing Parts, you can scroll down the page for details.
(Approximately half way down. Under the heading Removing the Drive Panel)
I find the instructions 'Less Than'
The Drive Panel is the Front Cover.
The Front Cover has to be removed, in order to remove either optical drive.
This is done by releasing the blue Slide Latch.
The blue plastic slide, on the side of the optical drive bays.
The plastic tabs are depressed, and the blue plastic slide goes towards the rear of the computer.
This allows the optical drive you wish to remove, to slide forward, and out.
I slide the drive I want forward a little, so that I can get my big hands on those cables.
You will have a 7-pin Data cable, and a 15-pin power cable to remove.
Installation is the reverse of these steps.
Jan 11, 2010 | Dell Dimension E520 PC Desktop
Hard Drive Upgrade
Yes, the motherboard should support that size drive with no problems. You will have to reinstall windows using the discs that dell sent you originally. Be aware the drivers for dell can be tricky to reinstall.
Oct 29, 2009 | Dell DimensionTM E520 PC Desktop
Dell Dimension case falling apart. Plastic on outside separating from underlying metal.
I'm not sure what you want us to do about this--as long as the computer is under warranty, you're covered.
Otherwise I'd suggest you get a tube of silicone seal and glue it back together. Won't affect the operation.
Oct 01, 2009 | Dell Computers & Internet
I have a dell E520. i don't know if i have pci express. How do i check. I don't want to open up my comp.
look on the mfg websight or make a phone call to dell
( screwed ? of course you bought a dell )
Aug 06, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Inside of PC is extremly dirty!
There should be a gray button type thing on the top of the back end of the case and the bottom. You will need to push both in at the same time to get the case open. Push both in and slide the case apart. I found that having somone pull the case apart while i push on the buttons is easier.
Let me know if how it goes.
Regards
Dec 13, 2008 | Dell Dimension 2400 PC Desktop
Dell DimensionTM E520 PC Desktop Logo
150 people viewed this question
Alun Cox
