Question about Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Black Screen Problem
Hello!
After I turn on power button, there is a black screen only and Caps Lock turned on, and also Num Lock and Scroll Lock are flashing together, and that is for about 10 seconds. After that, my laptop turns off.
It started, when using laptop normaly to browsing the web, in one moment it freezed. After that, the problem began.
I tried to replace battery, and connect notebook to the adapter, even without battery, effect is the same..
Please Help,
Best Regards
  • 2 more comments
  • mefhisto May 10, 2008
    I did, what you said, but it didn't help. But i replaced memory from slot A to B, and from B to A, and it works now! :)
    Thanks for help, anyway.
  • Neerajks Jun 05, 2008
    Hello!
    laptop turns off.
    Please Help,
    Best Regards
  • Anonymous Jan 08, 2009
    Exactly the same, no clue what is behind?
  • Anonymous Jan 17, 2009
    BLACK SCREEN
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 10, 2008
    Problem Solver:
  • 10 Answers
Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
  • 3,940 Answers
Flashing - ON -Flashing indicates a problem with the LCD. Reseat the LCD cable connection to the motherboard, then see if the problem is resolved. If not, disconnect the LCD from the motherboard, and connect and external monitor, see if the system posts normally (You may need to toggle Fn +F8 for external video) if it posts, the LCD/LCD inverter is bad. If it doesn't, the motherboard is bad.
2 Suggested Answers
  • 381 Answers
SOURCE: Hello! After I turn Dell
Could be a memory problem try removing the bottom panel, and remove both memory modules clean the contact and replace them in the slot
Posted on Jul 21, 2011
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Won't boot
was there any changes done to your system like upgrading anything
All your power seems to be on right
Dec 13, 2008 | Dell Inspiron 1525 Laptop Jet Black
Can't get num lock to work on Dell Inspiron 6400
The 5th key from the right on the top row of your keyboard should is the Num Lock Key...
Dec 08, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Screen turns black Problem
Could you please run the diagonistics on the computer?
Turn on the computer. When the DELL logo appears, press <F12> immediately. Select Diagnostics from the boot menu and press <Enter>.
NOTE: If you wait too long and the operating system logo appears, continue to wait until you see the
Microsoft Windows desktop. Then shut down your computer and try again.
b Press and hold the <Fn> key while powering the system on.
Make a note of any errors that you get after running the diagnositcs on the computer.
Mar 08, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
2,562 people viewed this question
Alun Cox
