Question about HP COLOR LASERJET CP 3505 N PRINTER
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being printed from Tray 1. I think it is having trouble picking up the paper. What are some possible solutions to stop this problem from occurring again.
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Posted on Mar 23, 2011
Error 13.20.00 - No paper jam detected. Printer prints is making a sound like something is caught in the spokes of a wheel. Any thoughts?
first turn your printer off from power button then unplug from wall this will reset it wait a minute or 2 then plug it back in it might of thought it was still jammed with paper at the time.
Mar 10, 2015 | HP Color Laserjet Cp3505n Color Laser...
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
Oct 08, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
My hp color lasejet cp 3505n show the follow message at the boot "INFLATE FAILURE SEND RFU UPGRADE" and nothing dont work
This error message occurs when there is an internal hard ware failure. Please send the unti in for repairing it.
Thanks and Regards,
Dr Tony
May 04, 2011 | HP LaserJet CP3505n Printer
I get an error message that there is a paper jam in the front door, there is no jam. I open and close the front door and then it says the jame is in the fuser, ive taken that out and no jam hp 3550 laser...
Often when you get this error, there is a jam that is very difficult to see. You need to open the printer, remove the bottom two cartridges and the transfer belt. Then close the door part way and look straight down inside the printer. That part of the printer is called the registraion assembly and there is a paper sensor in there that often gets stuck with a small piece of paper after a paper jam is removed. You can carefully lift up on that assembly to unseat it and have a look underneath..
May 03, 2011 | HP Color Laserjet 3550 Printer
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
Our printer CP3505n is having trouble recognising paper size although it is standard A4 this then results in a jam
Try specifying the paper size in the drivers. When you go to file print; click on either properties or printing preferences and change the paper size to A4.
Mar 31, 2010 | HP LaserJet CP3505n Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
HP COLOR LASERJET CP 3505 N PRINTER Logo
624 people viewed this question
Seeker5211
Seeker5211
