Question about Jenn-Air JGS9900BDS Stainless Steel Gas Kitchen Range
Ignitor for burner not working - Jenn-Air JGS9900BDS Stainless Steel Gas Kitchen Range
  • Jenn-Air Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 02, 2010
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Feb 15, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Jenn-Air JGS9900BDS Stainless Steel Gas Kitchen Range Logo
181 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
