Question about Husqvarna Viking 1
I have been sewing all day with no problems. Suddenly the needle is not picking up the bobbin thread. Why? Solution? Thanks!
  • Husqvarna Master
  • 7,365 Answers
The needle might be bent-roll needle on flat surface & see if it rolls correctly
if the needle is make a popping sound when it goes thur fabric the needle is blunt
check the bobbin area to see if there is lint or loose thread
check to see if the bobbin has become warped
the bobbin may not be inserted correctly in the bobbin case
check to make sure the bobbin case is inserted correctly into the machine
rethread the sewing machine in case the thread is caught somewhere
make sure there is a thread tail of 3-4 inches on both upper thead & lower thread
Posted on Sep 02, 2010
  • b waecgter
    b waecgter May 28, 2014
    I don't know if the bobbin case is in place properly. Is there a photo available? The case can fit in the space in more than one way.
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
On my Singer 6235 sewing machine, needle will not pick up bobbin thread. Any suggestions to fix the problem?
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Mar 01, 2016 | Singer Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
7. Warped needle
8. Warped bobbin
Feb 10, 2016 | Sewing Machines
Needle is picking up several threads from the bobbin after i have been sewing and jams
Remove the bobbin and case from the bottom. Try dusting it out and add a little oil. Also, check both top and bottom thread tensions. If that does not help then you may have a timing issue which requires a lot more technical expertise.
Aug 09, 2014 | Singer 3810
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
Jun 07, 2010 | Singer Sewing Machines
Machine won't pick up thread from the bobbin
I am thinking that you've threaded the bobbin backwards or have it in upside down. Does the needle drop down below to get the thread?
Jun 27, 2009 | Sewing Machines
Bobbin problem
Remove the race cover and jiggle it out. It is only stuck in there with thread.
O
oil the machine first. Then, determine whether or not you need any parts at all.
Jun 25, 2009 | Sew D'Lite SM-888 Mechanical Sewing...
Sewing Machines Logo
162 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
