Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water leaks into freezer compartment during defrost mode, drain to pan is open
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 02, 2010
When roper freezer goes in defrost mode it leaks
Assuming this is a unit with the freezer on top of the refrigerator, the drain is plugged and must be cleaned to allow water to flow from the freezer cooling coil during the defrost cycle down to drain pan, located under the refrigerator (in the compressor compartment.) Follow the leak up to see where it is leaking into the refrigerator and start from there to locate and remove the blockage.
Oct 20, 2014 | Refrigerators
Every couple of days there is a puddle of water coming from unit..shut off water source and still leaked water?! HELP!
Is the hose from the freeze compartment in the drain pan? Or is the drain pan leaking? The unit is going into a defrost and that is where the water is coming from. It drains into a drain pan where it evaporates over time......Check the drain line and the drain pan. Is there ice in the bottom on the freezer maybe the drain is pluged inside and the excess is seeping out the door during defrost. Hope this helps....
Mar 11, 2011 | Refrigerators
We have a leak inside of the refrigerator. Water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 20, 2010 | Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
When I close the refrigerator door the freezer door opens and stays open and create condensation and leaks below the refrigerator. How can I solve this?
The problems you have are related.
Jul 18, 2009 | Frigidaire FRS6R5EMB Side by Side...
Leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
