Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo Aquos LC-37d62u Display Problems
Hi there, I have a brand new monitor that I just hooked up. I am running my computer off it through the S video and am having problems cleaning up the screen. The resolution seems off and I can't figure out how to clean up the font. Seems very blurry and can't get a crisp font for the lettering. I am also using it for gaming and the graphics seem off kilter. Any help would be appreciated :D
~~Sunshine
  • JoesSunshine May 13, 2008
    We tried.. but, I replaced it with a 32 inch Sony that I'm much happier with (and it has DVI input LOL)
    Thanks everyone for your help :)
    Brigadier General:
  • 6,966 Answers
Have you tried lowering down your PC's Screen Resolution (lowest possible) and Screen Refresh Rates? Try and gradually increase until problem resurfaces. There could possibly be limitations with the S-Video.
Alternately you may want to consider using an HDMI to DVI Hi-Def Video Cable or even VGA to VGA cable. Of course depends on what are the available video output of your PC. Pls try checking them out here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 10, 2008
My sharp aquos lc 37d62u will not power on; the power light flashes 4 times, pauses and then repeats the 4 flashes. Does anyone know what this error code means? Thanks!
It is detecting shorted circuits or power supply problem, need in-depth troubleshooting. Inspect the power supply module first for any sign of bad caps with domed tops, DC output voltage readings check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Mar 28, 2011 | Sharp Aquos LC-37D4U 37 in. LCD Television
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
How do i Adjust My 40 inch Sharp Aquos to 1080 p?
You do not adjust the resolution at the TV, the TV will adjust itself to display what you are feeding it. It works the same way as the computer monitor, which is done on the computer's video card to what ever you set it to.
Nov 09, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- djstvrepair@comcast.net
Sep 10, 2009 | Televison & Video
Trying to hook my sanyo 32in up as a monitor for my computer running on windows xp when I hook it up it gets sound and acknowledges the cord is connected(the no signal sign goes away) but the screen just...
Your computer may be sending out a video signal that's too high of a resolution for your TV to display. Try reducing the resolution of the computer video signal.
May 13, 2009 | Sanyo DP32648 32 in. LCD TV
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp Aquos TV will not display contents of DVD using Microsoft Media Player 11
it sounds like a problem within your vga connection on the tv check around and see if there is some firmware for this fix or right click on your desktop were there is no icons and select properties select settings tab and set ur display as needed.
C
Oct 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Color pulses after LC-37D62U has been on a while
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
Feb 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
270 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
