Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
I have a kp51ws510 The color just started to flicker then it goes back to color then it will flicker then its black and white. What it going on. How could it be fixed
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
These sets are famous for bad picture tubes. It is normally either the blue or green tube that goes out in these. One way that you can usually tell, is to gently tap the neck(the glass tube at the bottom of each of picture tubes) w/ the handle of a screwdriver while the set is on and see if that will make it act up. If it isn't that, then there may be a loose connection somwhere on the board. You can also tap around on the boards to see if the problem occurs to find out if it's a loose connection. A picture tube will be costly if you can find one. They are hard to find and to change. You may need to get a tech to give you an estimate and see.
Posted on Sep 02, 2010
Benq w1000 projector
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | Office Equipment & Supplies
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Jan 23, 2010 | Sony KP-51WS510 51" Rear Projection...
White as pink, black as green
boot up your laptop and take a magnet in your hand and revolve around the screen the screen might go crazy but all the colors will be back in a while. :)
Mar 23, 2009 | Fujitsu AMILO PC Laptops
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Panasonic PT 51HX41E flickering colors
ok her is a good test for u, bring up the pip on screen and see if the picture is the same as the main picture ok.now if at is it sounds like to me that u have a bad pip board that is causeing your problem u can bypass the pip u just need to jump the video in to the video out and sync out and in and remove the pip most of time i have found that the small caps go back on the board and u lose snyc and that is y your picture goes black and white with blinking color in the background. now the stk392-150 is a better chip then what u had in it but convergence problem has nothing to do with color snyc. i hope this will hp u marty
Sep 18, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Jan 07, 2008 | Mitsubishi XD300U Multimedia Projector
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
