Question about Goodman CKL42AR42 Air Conditioner
Run Capacitor is bad... what is the correct replacement number for model cple30-1c? Thanks
  • 674 Answers
Look at the old capacitor. The rating should be printed on it. You just need to get one with the same microfarad rating. If you can't read it take the model # with you to heating and air supply that sells Goodman units and they should be able to help you.
Posted on Sep 02, 2010
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 29, 2017 | Carrier Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
I have a 38ckc036750 A/C Unit and the fan run when the contactor closes but the compressor dont, the is a hard start capacitor that is across the run capacitor. what must I do to get the compressor going....
many technicians make the mistake of using a hard start kit instead of replacing a bad run capacitor, the problem is that it can be ******* the compressor, and the start capacitor can also go bad, you can start with removing the capacitors and replacing with a new run capacitor and see if that gets it running, also can try another start capacitor with the new run capacitor, some manufactures engineer there systems in that way, if not the compressor may be done. *Be sure to check all the electrical connections including those at the compressor under the terminal cover.
Aug 22, 2011 | Carrier 38CKC036 Air Conditioner
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
My compressor keeps clicking on & off, and isn't cooling any longer
There is a start-up capacitor beside the compressor.When this capacitor fails, the compressor keeps clicking on /off.The capacitor is not very expensive.It costs near to $25.But if replacing the capacitor is not helping, then its faulty compressor causing this.The compressor is out of refrigerant gas and its getting short internally.You will have to get the compressor replaced.If replacing the capacitor not helped.The parts like startup capacitor and compressor can be bought from online sites like repairclinic.com or from sears parts direct site.----------- This will help.Thanks.Helpmech.
Mar 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a all in one or complete unit the fan motr
hopefully you replaced motor with the same Rpm HP Volts and made sure the rotation of fan was correct.. Might have a bad/defective motor I would take it back to whomever you purchased it from as the should exchange it. Good Luck
Jul 21, 2010 | Heating & Cooling
I have a Dometic 579 Series Brisk Air AC. The model Number is 57915.531. When I turn the fan on, nothing happens. If I reach up and turn the wheel blower the fan will start up and everything works. I...
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
I have an outside unit mfr Goodman, model # CKL-49-1. The blower motor isn't working. I'm able to hear it attempting to start. How do I check this motor to see if it's bad? Thanks
You have bad capacitor on your unit it may not look bad but chances are it is just get the microfarad rateing of the side of the cap. should be like 55.5 55 7.5 something like that. Also check your fan motor. last. I have changed hundreds of caps this year. Russ
Jul 16, 2009 | Goodman CKL36AR36 Air Conditioner
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
MODEL # CARRIER 38XD124300
sounds like you had a condenser fan replaced ok you just have verify if the fan is a reversible one there is like a plug type connector on top of fan all you have to do is swap the position of the plug ex. if black / white to white/black that changes the rotation. check against the diagram it should be for the CCW position.
Apr 20, 2008 | Carrier 38CKC036 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
214 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
