Question about Microwave Ovens
I need a manual for a Toledo 8427 Scale? - Microwave Ovens
Manual
Posted on Oct 11, 2011
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
My display screen is reading de-scale and i don't know how to fix it it is for a kuerig coffee maker
It needs de scaling by the description.
Consult your manual and use the prescribed chemicals to carry out the operation.
Hope that helps.
Jan 22, 2011 | Microwave Ovens
I need the food code manual for my chefmate digital scale
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and Installation Instructions as required.
I hope this helps.
Jan 06, 2011 | Microwave Ovens
Where can I find a user's manual for a Toledo Scale meat slicer, model#5401?
looking as well for sharpening stone for model 5400-0-001
Oct 22, 2010 | Microwave Ovens
I need to get manual/user's guide for scale CAS LP 1000 (need to re-program the scale...) Thanks!
you can find the user's manual on the CAS corp. site..here's the link...just scroll down to the downloads section on the left and u can download there http://www.cas-usa.com/lp1000n.html
Oct 18, 2010 | Microwave Ovens
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Microwave Ovens Logo
532 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
