Question about HTC Desire Cell Phone
When I try to set up time and date the phone can not find my timesone. I enter this manually no luck
  • 115 Answers
Do a reset.go to settings-system tab-look for clear storage. back up contacts and files first to sd card and remove sd card before doing so. OR try to sync your phone to your computer to set the date and time.
Posted on Sep 02, 2010
HOW TO SET DATE AND TIME
You need to set the date and time from the default extension "the programming extension" normally extension 20 or 21. You need to enter system programming mode - refer to user manual, then once set, all handsets should display the correct date and time.
Sep 23, 2013 | Panasonic KX-T7730 Corded Phone
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
How to set time and date
go to setting, then time and date settings and then set time and date
Feb 24, 2010 | Lands Phones
Cannot set date & time on Panafax UF-895
To set the date and time, do the following:
  1. Press function 7
  2. Press 1
  3. Press SET
  4. Enter date and time using 2 digits for month (sept 09)
  5. Enter 2 digits for Date
  6. Enter 4 digits for year
  7. Enter 4 digits for time (military time ex: 3pm 1500)
  8. Press SET
  9. Press STOP
The date and time are now set. Best of luck.
Greg
Aug 24, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Setting Date And Time
By Settings/Time and Date switch Time zone updating to Manual Only. Now you can set time and date below
May 31, 2009 | Samsung S8300 Ultra Touch platinium-red...
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select On, the phone will
automatically update the date and time.
Jan 03, 2009 | Cell Phones
Date & time
Try to see in your settings of time and date are set to automatic or manual.
Oct 15, 2008 | Nokia N73 Cellular Phone
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
HTC Desire Cell Phone Logo
26 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
