Question about Samsung CLP 300 Laser Printer
I cannot close the back cover of the Samsung CLP-300 after fixing a paper jam!
  • 2 more comments
  • patriquillo Sep 01, 2010
    Hi e-guru, what do you mean by "turn it the opposite way"? I've seen this solution on the web and I don't understand what that means. The thing cannot actually be moved!
    I've seen the answer provided on the web. What I need is an answer from someone who actually knows how the Samsung CLP300 printer actually works!
  • patriquillo Sep 02, 2010
    Yes they do face down but I still cannot close the lid. What are the pieces of the feeder that are mentioned on previous posts? Any image of the thing and how to operate it welcome.
    Many thanks
    New Friend:
Just had this problem.
When you open the rear door there is a rod with two black pieces that the gray fins on the door fit into slots on. Mine got flipped somehow.
If you carefully pull on the rod and flip the black pieces down so the square part of the black piece is up and back the door will close.
Posted on Dec 11, 2013
  • 3,083 Answers
Make sure everything is seated correctly, first of all. Anything slightly ajar can break a part of the door assembly, and just make the problem worse. Try to ascertain what is jamming the door, or where it isn't fitting. There's no easy thing I can tell you, since I can't see it, but make sure a latch isn't stuck in a wrong position, and anything can can obstruct it.
One fellow from fixyourownprinter.com had this to say about this problem:
I have a toner cartridge box wedged against the back of the printer so the printer will operate. The back door will not stay closed and after it was poorly repaired by their service tech, this is my solutiion operate the printer. The printer doesn't work if the doors are open either.
Not good news if the service tech couldn't fix it, hmmmm.
You might try calling the service people, just to see what they say. Here's their support website:
http://www.samsung.com/us/support/download/supportDownloadMain.do
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 02, 2010
  • 526 Answers
Check to see that the green levers on the fuser are facing down.
did that help?
    Brigadier General:
  • 3,917 Answers
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 printer jams when using legal size paper. I've changed the paper size in the properties menu and it still jams every time. Help.
Make sure the paper setting in the printer driver software is set correctly. Sometimes that can cause this problem.
Aug 04, 2009 | Samsung CLP 300 Laser Printer
Can not close the back cover
a Samsung tecahnician justed fixed it for me. The feeder (at the back cover) just in wrong position, turn it to the opposite way and he recommended that next time if the paper jam no need to open the back cover just turn the printer off and then turn it on, the paper will feed out. But it case you have done as he recommend and it still jam, open it would be possible. (the Feeder I'm not sure what it's call, it were 3 piece of black plastic)
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Cannot close the back cover back.
when you open the back cover you will seee a metal ber with 4 grey roller on it. There are 2 black plastic bit spanning the rollers (2 each one spnas 2 rollers). these need to be pushed upwards so that the click up (the back of the plastic bits will push past the bar behind as the bar they are on flexes). once you have done this the cover will close. It only took me 2 days to figure it out....
db
Samsung CLP-300 - Cover Open error message, but covers are closed
Front cover is on the right hand side, back is on the left hand side in the middle, and the top cover is like a little button on top. All the others are little openings.
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-300
Open all the covers and close all of them , See any changes if not remove the toner cartridges and see any paper jam in the tray or else. If nothing works out see any sensor is broken physically and update me.
Feb 27, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
