Question about Sylvania 6719DD 19 in. TV/VCR/DVD Combo
VHS Tape is stuck. Tried unplugging and plugging back in while holding the eject button but that only oped the door then closed the door to the tape.
  • Sylvania Master
  • 12,061 Answers
Hi, I see this problem frequently, what has happened is the Tape loading motor has failed, or the driver for that motor has failed or the Mode switch, has.
If you wish to DIY, you will need a service manual, I have given you a link below.
http://www.tradebit.com/tagworld.php/sylvania
However if you do not wish to DIY, then please contact a Sylvania authorised service center, then ask for a "Quote" for the repair.
Unfortunately, these days many seemingly simple repairs can cost almost as much as a new unit, WITH a warranty.
Often I find it is better for customers to put any monies they would have spent on repairs into a new unit.
Posted on Sep 01, 2010
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Tip
How to eject a stuck vhs tape.
I will show you how to eject a stuck vhs tape. I did this on the sony slv-d300p first, unplug it. Next, take out all the screws on the back. Take off the cover. Locate the loading motor on the right. Turn the gears next to it. After about 5 minutes, the tape should eject. While its open, take a CLEAN piece of paper, hold it up to the drum, and rotate it with the paper against the back. after 5 minutes, take the paper off and stop spinning. the paper may be dirty. put the cover back on, and try to put in a vhs c adapter with NO vhs c in it. when you put it in, it should spit it back out.
on Jul 15, 2010 | Televison & Video
VR 470 VHS VCR
there is no manual wheel.
Apr 12, 2008 | Televison & Video
VHS tape is stuck in the machine. How do I remove it?
This is often a frustrating problem but if you feel you can handle it go ahead with the following, otherwise get professional electronics help. If you have tried to eject the tape and tried other obvious ways to extract the tape and nothing has worked then you can remove the top cover and manually remove the tape. It is not that hard to do most of the time. First unplug the power cord from the wall outlet. You do not want to get a short or get shocked or zapped. Just unscrew the screws holding the cover in place and set the cover aside. Look at the tape to see where it is hung up. If you need to push the tape around so you get it off the posts or otherwise free up the tape, then gently do so until you free the tape from the tape transport. Sometimes this is all you need to do to extract the tape. You may be able to push out the tape from the VCR at this point. If you can get all the magnetic video tape back into the cassette but the tape simply will not come out then place the cover back onto the VCR, plug the VCR into the wall outlet, power on and try to eject the tape now. Sometimes this works. If all else fails, take the VCR into a electronics repair shop and have them remove the tape for you. They may tell you the VCR needs repairs also so this does not happen again.
Mar 31, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
VCR Won't Eject VHS Tape
Do not panic yet! Before doing anything else just unplug the unit for a time. On two different occasions I unplugged my TV/VCR combo, it reset itself and I could eject the tape. I do not know how much time is really necessary as I let mine sit overnite in those two instances.
So after much frustration the first time a tape stuck which included carefully opening the chassis to look for a twisted tape, sticky labels or loose parts in and around the metal cassette holder plates, I put it back together. Now I just unplug to reset.
I am not saying this will work in every instance, but give it a try first.
Aug 20, 2008 | Zenith ZHX-313 System
Tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Oct 17, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Cannot get Tape to into camcorder
Have you tried using the cleaning tape ?
Jun 02, 2017 | Sony Handycam CCD-TRV107E Camcorder
Sylvania 6719DD 19 in. TV/VCR/DVD Combo Logo
194 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
