We have a Whirlpool AWM 5104. When the machine comes to the spin cycle the machine stops, you can turn the dial and it will carry on.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
Hi guys, I have an intermittant fault on my washing machine, can you help? Its a Whirlpool AWM 1400 Spin. The control timer knob dial thing, sometimes stops halfway through a wash cycle. But if you...
Sounds like you may have developed a bad spot in your timer. Easy enough to replace and you can probably get one fairly cheap on eBay. If it was the water level sensor, advancing the timer manually wouldn't work.
Dec 31, 2014 | Whirlpool Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Hiya, i have the AWM 5104 and i was wondering how i can clean the filter as our clothes are coming out with gunge on them!
run some affresh through the machine. also make sure you are using HE detergent. run the cleaner at least once a month
Feb 21, 2010 | Whirlpool AWM5104/1 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
