Question about Kenmore 54622 / 54624 Side by Side Refrigerator
Is it possible to remove the ice/water piece from the door? If so, what is the best way to remove it in order to not break it?
SOURCE: Whirlpool GD5SHAXKQ00 Ice/Water dispenser
Hey,
It's pretty easy to remove by yourself. DO NOT force it or it will probably break. Nice and easy will do it. You'll need a flat headed screw-driver and a towel.
-There are 4 retaining tabs. 2 on top and 2 on the bottom.
-Remove the drip tray in the dispenser area
-Start with the bottom. Before starting, look underneath the surround (yes--bend down, stoop or lie on the floor -- your preference) You will see 2 thin slots. That's exactly where the tabs are. Do one tab at a time.
-Place the folded towel under the surround at the same time you are placing the screwdriver tip gently at the slot---DON'T apply pressure to the screw-driver yet.
(The towel will protect the paint and by being folded will provide a slight leverage for the screwdriver) Hold the towel against the door with the same hand you're holding the screw-driver with. If you can't....then cry for help.
-With your free hand press down firmly on the lower part of the surround (where you removed drip tray from) ...at the same time GENTLY pry with the screw-driver.
It shout pop out pretty easily.
-Repeat for the other bottom tab.
-For the top tabs, lift the entire surround up and then out.
-Remove the wiring harness and VOILA!!!
-Show off to your wife.
Posted on Jul 03, 2008
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
Sea Breeze
  • 4655 Answers
SOURCE: need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
http://servicepartstec.blogspot.com/
Posted on Mar 30, 2009
rylee_smith
  • 8619 Answers
SOURCE: Ice maker made ice until we replace the water line
Hi!
Pleae check to see whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Thanks
Rylee
Posted on Jun 19, 2009
aasc
  • 1606 Answers
SOURCE: Ice won't dispense, suspect switch in door cover. how
Insert a small putty knife between the dispensor plate and the dispensor cover about 1-2 inches from the sides and press down and inwards . Do this carefully because there are 2 plastic "clips" at the bottom . Once bottom is free , lift upwards and the cover will come off . Remove the plug and it's free . There is a white contraption , large , that have 2 rods the micro switches clip onto and sometimes , the switch on the left , has the broken rod holding the micro switch . This causes no ice dispensing .
Posted on Aug 15, 2009
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Feb 24, 2014 | Woods Upright Freezer MU07W
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
I am getting little white pieces of something in my melted ice from my kenmore in door ice maker. Nothing in the water though. What can this be and is it harmful? How can I fix this? The fridge is 4 m
This is the calcium minerals in your water. They are forming on the inside of your ice maker and then the deposits are setting up in your ice. You are also getting this in your water, but the deposits do not stick together so you do not easily see them. You can remove the ice maker and clean in a vinegar solution to break down the minerals. This will be an ongoing issue, but at least you can manage it and it is not harmful.
Jan 13, 2014 | Kenmore Refrigerators
Water leaking in ice cube tray - makes chunks of ice in ice container
Hello, Thank You for using FixYa. I will be helping you today.Are you sure water is leaking? This ice bucket is famous for all the ice clumping together! Some of the reasons are,Not using the ice dispenser enough,Crushed ice getting stuck in the ice chute door allowing warm air in to melt the ice,Ice door not closing all the way,Opening and closing the freezer door allot,But like mentioned before not using it every day is the main reason.You should remove the bucket every couple weeks and run hot water through it.If it ever gets stuck on the door you have to remove as much ice as possible and then use hot water to pour in there and catch the water out of the ice dispenser until it will break free.There are allot of service calls for this and never have i seen any icemaker that leaks if it is you have to replace it.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool GoldĀ® GC5NHAXSY
Is it possible to remove the front of the piece where the water and ice come out the front door
The front cover is removable but the main housing is part of the door and cannot be purchased seperate from the freezer door, so be careful......
Oct 13, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice dispenser has black ugly gunk from which the ice drops. It is the rubber flapper that opens and shut that is dirty. Question. can the rubber flap be removed to wash?
It;'s possible, but not recommended. The pin that holds the door into place is metal, but the hinges are plastic and have been known to break pretty easily. They do make a replacement kit in case you break the hinges, but that job is usually best left to a professional.
Aug 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side 2000 refrigerator with water and ice dispenser. The ice does form in the tray but the piece that strips the ice from the tray is missing. I have ordered the piece to replace. The ice...
Hi, I think you need a new icemaker. What you described seems like water is getting in ice bin with the auger. Either to much water to icemaker and it overflows or if your talking about the rotating strip fingers for the icemaker is missing then yes that is the problem. If ice don't come out of tray and it still cycle it pour water on top of ice and into bin with the auger.
Sep 08, 2017 | Kenmore Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 54622 / 54624 Side by Side Refrigerator Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
