posted by vasforu on May 10, 2008
Anybody Know IBM Thinkpad Adaptor opening ..There is no screw i found on it.
Comment by vasforu, posted on May 13, 2008
I have an IBM thinkpad T30 and when the laptop is NOT plugged
into the wall using the AC adaptor, windows battery icon shows the
laptop as still being on AC power. It always shows it that way and
always says charging even though it can't possibly be doing so. Plz, let me know. It would be most appreciated. Thanks.
Comment by vasforu, posted on May 27, 2008
Dear....shaggyrat...There is no switch like that in T2366 T30 thinkpad. I already opened and seen the IO board. Anyway thanx for your reply....
Can Anybody know Which is the internal switching IC in Thinkpad T30 2366....
Please help me to solve my problem....
1 Other User Has The Same Problem
Comment by cristianene, posted on Jun 03, 2008
I have a T43 model 1871 f1g
I don;t know what happened, but it shows that it's always plugged in the AC power, even if it's not!
The bad thing in this is that... it doesn't beep when it has low batery, it shuts down when doesn't have any power left
Clarification Request
by nai6378, posted on May 11, 2008
which thinkpad are you using?
Best Solution
posted on May 26, 2008
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
Comment by shaggyrat, posted on May 31, 2008
its not on inside its a switch to go from power to battery its called an inturupt switch this will come off the plugin socket some laptops are being ran off a jumper switch io switch which in side if you have your laptop specs for mother board will show it follows along the solder lines to the battery inputs there you will see io jumper switch and how to disable this from showing
Rating Locked! (?) vasforu has rated this solution as Inappropriate
Suggest a new solution for this problem
Post a New problem for IBM ThinkPad T30 2366 PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
Repair Service
Find PC Laptop Repairman Near You:
