Question about Brother DCP-330C All-In-One InkJet Printer
Brother DCP 330C comes up with Unable to print 34 and the photo capture light blinking in red
pineworks
  • 4041 Answers
SOURCE: brother printer dcp 330c - unable to print 50
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
nandini789
  • 430 Answers
SOURCE: unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Posted on Aug 21, 2009
pineworks
  • 4041 Answers
SOURCE: unable to clean 46 error
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Press 80
Posted on Apr 28, 2010
SOURCE: brother dcp 330c unable to
print unable 4f
Posted on Jul 15, 2010
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
My printer DCP-330C is saying ''unable to clean 46'' and will not proceed. If I switch off and on it still says the same. What can I do?
try to reset the printer..
with the printer powered up press
menu
mono start
up (x4)
then ! and photo capture start flashing
then use the up key to select the number and the sed key to enter it
so
8 set
0 set
mono start (x24 "purge:XXXXX eg 06451")
up key (2) set
7 set
8 set
3 set
then screen shows purge:00000
stop/exit key
up key 9 set
9 set
then your done ready to use
thank you
Dec 01, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to print 46
Aug 14, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-330C All-In-One InkJet Printer Logo
104 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
