Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor oven code FO means keypad is in depressed mode.....and then what?
    Genius:
  • 1,157 Answers
Hi john56584,
The "F0" error code description is a stock function key. Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F0 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 08, 2011
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: dacor oven code FO means keypad is in depressed mode
Hi minnabristol,
The F0 Fault Code Description is "Function key stuck". The only solution to this is to replace the touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Posted on May 18, 2011
What does FO code indicate?.
I showed you what it means before. Did you follow the links?
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced http://products.geappliances.com/appliance/gea-support-search-content?contentId=16238
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). http://www.appliancepartspros.com/repair-help/dacor-fault-codes.html
Dec 03, 2015 | GE Ovens
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
My Dacor RSD 30S has an Error Code FO
first off you need to find the description on the code see what it stands for .then a repair issue can be looked at!
Jun 19, 2013 | Dacor Preference RSD30 Gas Kitchen Range
I have a Dacor double oven that gives a error message of F0 and then shuts itself off.I don't have the manual so I don't know what this error code means or how to fix it.HELP!
F0 means shorted keypad or stuck key on keypad.
Solution: The membrane aka keypad has to be replaced.
There's a slight chance that the ERC aka oven controller is acting up also.
So safest bet replace both, ERC and membrane.
Dec 24, 2010 | Dacor ECD227 Epicure Electric Double Oven
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
KENMORE OVEN HAS FO ON KEYPAD.ANYTHING I CAN DO BEFORE REPLACING KEYPA..MAYBE RELAY SWITCH
Hello,F0,displaying on your keypad means "stuck keypad" and these mean the relay is turned on and to determine if the problem is with the Key Panel or Control,follow these steps
1. Pushing Clear/Off pad
2. Disconnecting Ribbon Cable from control and wait at least 30 minutes to see if the code reoccurs.
If the code reoccurs, the problem is in the control, that means you have to replace the control.
If the code does not reoccur, the problem is with the Key Panel
Thanks
Jun 03, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Dacor 48" range, double oven. ovens do not work. Letters FO appear on the display. Any suggestions?
F0 means: Clock pushbutton is stuck in a depressed position. Check clock buttons. You might need a new touch pad.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Ovens
Hi minnabristol,
Hope it helps.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
309 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
