Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
GE TPG24BF Not Defrosting
Hi, I have a GE, about 5 years old, hard to find information, its a 690L side by side with water and ice maker. After it runs a few days the "DE" light flashes and the fridge is not defrosting. The heater circuits are fine. Any suggestions please.
Pete
    Genius:
  • 1,073 Answers
Replace the white sensor located on the top of the evaperator coil
Posted on May 10, 2008
Ice maker problem
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | Frigidaire FRS3R5EMB Side by Side...
LG 26930tt side by side refrigerator water leaking
Make sure the unit is not all iced up, try to defrost it and then retry, turn off the ice maker and water supply before defrosting. Put a thermoter in the freezer to check temp.
Aug 30, 2009 | LG LRSC-26930 Side by Side Refrigerator
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Dec 22, 2007 | GE Profile PSI23NCR Side by Side...
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Open Questions:
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
149 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
