Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain 1/2 HP opener. Just installed it. Get no movement. Light blinks 10 times.
    President:
  • 3,197 Answers
This is a door sensor problem. Either they are not pointed at one another, they are hooked up wrong or you didn't install them. Make sure the small light on each one is lit and not flickering ever so slightly.
Posted on Sep 02, 2010
Garage door automatically reverses if you cross the safety beam when door is in upward travel
something is wrong supposed to reverse on downward movement only as not to crush you.. in upward not supposed to do that.. call chamberlain 800 number
Jan 25, 2015 | Chamberlain 1/2-HP Whisper Drive Belt...
Have a Craftsman 1/2hp garage door opener (HBW0777 year 1994). It won't close and goes back while blinking 8 or 9 times. Transmitting sensor (red light) is blinking 3 times (even i hold the two sensor...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. If the transmitting sensor light is blinking it is bad.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 1/2 HP door opener. When I attempt to open the motor clicks but there is no movement. I have tried reprogramming but the issue continued. The indicator on the back is blinking, the light...
Check your door springs. Could have a broken one. Also remove the cover from the motor unit and check the drive gear. It could be stripped. If the light on the back is blinking randomly that is normal. It can also send a code. See if it blinks a number of times, pauses and then repeats.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 102-1499A Opens w/ remote. Will not close w/remote.
If when you try to close the door the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 hp security door opener
OWNERS MANUAL FOR ALL CHAMBERLAIN MODELS ARE AVAILABLE (FREE PDF) AT CHAMERLAIN.COM
CHECK TO SEE IF THE LED IN THE WALL BUTTON IS BLINKING - IF IT IS PRESS THE LOCK BUTTON AND IT WILL STOP THEN TRY TO PROGRAM YOUR REMOTES.
IF IT IS NOT BLINKING TRY UNPLUGGING THE UNIT FOR ABOUT 5 MINUTES - PLUG IT BACK IN AND TRY TO PROGRAM THE REMOTES
HOPE THIS HELPS
May 19, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
When our garage door opens, my light turns off immediately. How do I get it to stay on for about 5 minutes?
Try this:
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
IChmberlain Garage door does not pen or close
The light flashing 5 times is the code for "RPM sensor or motor overload" and the 10 clicks sounds like the relay for the main light bulb that flashes when the door sensors are blocked or misaligned.
If you want an owners manual and have Adobe Reader you can go here and get one.
http://www.chamgerlain-diy.com/pdfdocs/A2490M.PDF
Oct 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
For 1/2 HP belt drive opener: With the belt off, the motor sprocket only turns 1/8 - 1/4 turn each time the door opener button is pressed. Although nothing is obstructing the door or the sensors, the...
If the main light blinks 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. Tweak them a bit if necessary.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't shut, light blinks 10 times.
If the light blinks 10 times it is a sensor problem. Nothing else will cause this. Tweak the sensor a bit and check it out.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
148 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
