Question about Estate EGD4300SQ Gas Dryer
Where is the ignitor located and how do you get to it
  • 12,061 Answers
Http://www.allrepairmanuals.com/estate-dryer.htm?model_number=+EGD4300SQ
Hi. please find above, a link for a service manual, this manual is invaluable in servicing your unit. It shows ALL parts placements and part numbers.
Really one simply cannot do the job without it.
Posted on Sep 01, 2010
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Where I's the ignitor located on my samsung dryer?
It is located inside the dryer cabinet.
Feb 06, 2012 | Samsung Dryers
Hello Shirley,
The ignitor is located on the main bake burner..to access it ya would need to remove the floor from the oven which is typically held in place by a couple over sized screws,remove those screws and lift off the oven floor and the ignitor will be their.
GENE
Nov 06, 2011 | Tappan 30IN ELEC IGNa Oven
When we turn on the broiler or the oven it will not heat up inside. The warmer drawer works. The screen is fine and its like it will heat up but stays at 100 degrees. Is this the ignitor switch? or is...
Hello, Thank You for using FixYa. I will be helping you today.This sounds like an ignitor issue.When the ignitor starts to fail it will glow enough to add heat to the oven or the default for the oven is 100 degrees.The ignitor is located under the bottom inside the oven,Sometimes it will glow but it dont let enough power through to open the gas valve. I would say its an ignitor issue.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kitchen Ranges
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
How to change ignitor on 1991 honda accord
Honda has 2 distributors, Hitachi (with an internal ignitor) and Toyo Denso (with an external mounted ignitor). The toyo denso is removed by removing 2 bolts and a harness clip on the outside of the distributor. The Hitachi requires that you remove the dist. cap, rotor, and 'reluctor', which is under the rotor, the ignitor is under that, remove the retaining screws, make sure the screws are put back in the same locations, as one is a 'diamegnetic' screw, and must be replaced in the correct location.
Nov 16, 2009 | 1991 Honda Accord
How to install ignitors on Viking Range
Sep 07, 2009 | Viking VGIC485-6G Gas Kitchen Range
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
Ignitor not working
Yes, electrode is also called as ignitor. Both are same.
May 15, 2008 | Amana AKS3040 Gas Cooktop
Oven won't heat
This could be the ignitor. The ignitor is located under the bottom of your oven. you get to it from the inside of the oven. A quick check though is to set the oven to bake and wait about 30 seconds and see if you can see a faint orange glow from the bottom inside of the oven. If you do then your ignitor is probably working ok and the problem lies somewhere else.
Apr 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Estate EGD4300SQ Gas Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
