Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do i make my computer except my epson nx110
  • Epson Master
  • 5,062 Answers
What OS are you using? Drivers and software are available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&prodoid=63084353&infoType=Downloads&platform=All
Did you install the software before connecting the printer? If you didn't, uninstall the OS basic driver, unplug the data cable and install the appropriate one from the above site. Then reconnect when prompted.
Try a new data cable (scanners can be extremely sensitive to cable problems but a really bad cable will not let the printer talk to the computer at all). Make sure the cable is 6' long or shorter. If you use a print server or USB hub, try a direct connection. Check that a known working device works in the USB port. Make sure that the USB ports are active and not powered down for energy savings or security. (In Windows the first is part of the Advanced Settings from the Screen Saver set up control panel; the second is in the Device Manager.)
Is the computer with the problem connected directly to the printer or is another computer serving as a print server? If it is the latter, make sure that the firewall isn't blocking access. Make sure that the printer is a shared device (Devices and Printers (or Printers and Faxes), right click on the printer's icon and choose Properties. Then adjust the Sharing properties on the host computer.
I hope this helps.
Posted on Sep 02, 2010
My epson stylus nx110 will not power on. whats going on?
Find something electrical and plug it in to the wall socket to prove you have power there.
Make sure the wire is plugged into the back of the printer it is has a removable lead. Check if there is an off switch in that area.
Still nothing? It needs to go back.
All the details on your printer including troubleshooting tips are here. I recommend Canon or HP.
Epson Stylus NX110
Jun 27, 2016 | Epson stylus nx110 All-In-One InkJet...
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
I lost my installation cd how can I install without it
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Jul 12, 2012 | Epson stylus nx110 All-In-One InkJet...
How do I LOAD CARTRIDGES INTO MY EPSON STYLUS NX110 PRINTER
Follow the link below:
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Click "replace ink cartriges" on the left of the page
and then select "Remove and install Cartriges"
May 04, 2011 | Epson stylus nx110 All-In-One InkJet...
Have an epson stylus nx110 printer and have to replace ink cartridge. the cartridge holder will not go into place so that i have access
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Mar 13, 2010 | Epson Stylus NX400 InkJet Printer
New computer. no cd
You can get the driver from this site:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGs8xyY6tppQqeurEYBTh8ntD7N++kOb2oU003D&tc=6
Feb 26, 2010 | Epson Stylus D92 InkJet Photo Printer
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
My new epson stylus NX110 wont download into my computer it said it needs a driver
You need to install drivers to have the operating system recognize the device. The unit should have come with a disk. If not, you can go to the epson site and download the driver, and other software for your device.
Dec 17, 2009 | Epson Computers & Internet
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
175 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
