It says 0% and even if I plug it , it still is not charging
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Sep 08, 2010
Dropped my new zte n9130 boost mobile phone when it was just about dead . Went to charge it and no light no charge and not turning on?? Is this product a good one?
You may have knocked loose the little "plug" that your charger fits into to charge it. It is soldered onto the board inside and, and if it is no longer attached it won't charge anymore.
See if the plug jiggles a bit if you play with it when a cord is plugged in. If it moves that is a problem and means that you need a repair. Even if it doesn't move, it may just be packed in there tight but is still broken.
Sep 10, 2015 | ZTE Cell Phones
Camera S5200 nikon said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
give it some time to charge up maybe? Ive seen electronics, even tho plugged into a power source, wont power on until theres a bit more charge on the battery, Idk why, but thats my only suggestion
Nov 01, 2013 | Cameras
Emerson emp287c-4 wont charge with usb
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
Dec 26, 2012 | Emerson Televison & Video
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
Plugged it into my computer, now wont even turn on!
HI,
TURN IT ON WHILE ITS CHARGING WITH COMPUTER,SOME TIME THERE WILL BE STROKING ON PROLEM..
TNKS
RABBANEES
Nov 04, 2009 | Pure Digital Flip Video Ultra Camcorder
I charged it. And now it want turn on or even light up. I plugged it back into the compulter and it still want even light up.
My ipod was fine and then the battery died. Now im trying to charge it but it won't work, the screen is always black, and it doesn't even turn on itunes when i plug my ipod into the computer, what shoudl i do??
Mar 07, 2008 | Audio Players & Recorders
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
