Question about Health & Beauty
If an electric wheelchair got wet or water on the joy stick will it damage it?
  • 692 Answers
I guess it depends on hw wet. Yes water can damage your chair especially the joystick. It can cause the circuit board in the joystick to short out. If the chair's motors get submersed in water then it can short out the motor but it will cause rust to build up in the motor case and also cause the electric brakes to seize then the chair won't move. If you got light water on the joystick wipe it off quickly and you should be ok. If the joystick comes on and you can still drive the chair then you are ok. I always tell folks to carry a plastic shopping bag in your chair in case you get caught in a shower just cover the joystick and you can still drive the chair with the bag over the joystick. Hope this helps you
Posted on Sep 02, 2010
What does 3 blinking wrench lights mean?
It is indicating a left motor fault, which is not good news. This is usually from a motor overheating and burning out, usually from overloading the chair or from driving it on unstable terrain like mud, snow, wet grass or sand. If that is the case, there could be more damage to the electronics once you get the motor replaced too. Replacing the motor is a lot of work and very expensive, so you may want to try to find a replacement chair.
Feb 06, 2015 | Electric Mobility Invacare Pronto M41...
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
The problem i have is with my fathers rascal scooter. when he turns the key to the on position it will go in reverse without him touching anything.
sounds like the joy stick is damaged, you may be able to sort it by reprogramming, go to a mobility shop and ask, if it can be done then they may well do it free, hoping to get your custom in future.
Sep 19, 2013 | Electric Mobility Rascal Scooter...
Error code 80 and then 138 quantum edge w/c
Low voltage. Check the batteries and connections to the power module and joy stick. Make sure no loose connections are present.
If problem still persist, then maybe new batteries are needed.
Sep 16, 2013 | Quantum Edge 6 Wheelchair - Used Electric...
My power chair got wet in rain and won't start and lights olny flashing and what is meaning of vsi? how to ftx problem..please help!
VSI is the controller under the joy stick. Water will ruin the electronic circuits . The controller is expensive new. You can find rebuilt ones cheaper or can have yours rebuilt. Check your local mobility service shop or on line repair facilities.
Oct 12, 2012 | Pride Go Chair Travel Power Chair
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
Joystick not moving chair,a blinking light on keysign on joy stick panel
You need to check the little fuse and see if it is blown, if it is replace it, if not, it is like a 'check engine light' on a car, most of the newer chairs need a diagnostic test ran.... Guy
Sep 06, 2010 | Dmm Allure HP6 HD - Used Electric...
Health & Beauty Logo
179 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
