Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a cub cadet riding mower with a kohler 12.5 hp engine. the problem is after i start the mower it runs fine for say 2 minutes. it starts choking out like it is out of fuel and the exhaust smells lean. i have replaced the fuel cap, fuel line, fuel filter, air filter, cleaned the carb, and replaced the magneto... it is driving me nuts..can u help please ?model # 133-233-100, serial # 254224. year modle 2003
  • 41 Answers
SOURCE: Cub cadet 20 HP Kohler starts up and dies
check your air filter. hope this helps
Posted on Aug 08, 2009
rtpflh
  • 546 Answers
SOURCE: No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Posted on Oct 06, 2009
Dolfoff
  • 148 Answers
SOURCE: I have cub cadet 129 with 12 hp kohler cast iron
This would most likely indicate an air leak in the intake tract. Another possibility would be a partially clogged main jet in the carb. Either problem results in a lean running engine with VERY high exhaust temps. Bad news if not corrected.
Hope this helps,
Dolf_
Posted on Nov 01, 2009
Testimonial: "thanks"
  • 468 Answers
SOURCE: I have a cub cadet with a kohler command series 16
This usually means that is's been overfilled with oil, or the engine has been tipped enough for oil to run into the cylinder. Drain oil if it's above the line at all, and the problem will go away once the oil's burned out of the cylinder.
Posted on Mar 29, 2010
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
I have cub cadet 129 with 12 hp kohler cast iron engine when it runs for about 5 minuts the muffler gets cherry red does any one know why?
Hope this helps,
Dolf_
Nov 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cadet does not fire
is it the 12 hp kohler? if so it is electronic type no points.
have you tried cleaning the flywheel magnet and coil?
use very fine sandpaper and clean them. if still no go gheck kill switch and nothing there is is probally a bad coil.
Jul 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
85 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
