Question about Apple PowerBook G4 Mac Notebook
When i turn on the mac it come up to the apple, then a cmd prompt is in the left side and I cannot seem to get past this, i cannot even shutdown, unless i hold the power button or remove the battery...any help? and I dont know the hardware/software in it.
    Scholar:
  • 183 Answers
You have a firmware problem and it needs to be reset.
try this first: If the computer is on, turn it off. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
Wait 5 seconds.
Press the Power button to restart the iBook computer.
If that doesn't work, try this: Turn the laptop off. Remove the battery but leave the mains power attached. Hold the start button down until you hear a loud beeeeep! then release. Wait for the system to reboot and hopefully thats you sorted.
Posted on Sep 01, 2010
Copy and paste for dummies
You're following instructions for an IBM-style machine and mouse. You need to be reading instructions for Apple. Often their version of a 'right-click' is to double-click, but it depends on the program. Read your manual about using your mouse, and always look for Apple-specific instructions for any program or application you are using.
Aug 14, 2014 | Apple Imac 17" Desktop G5 2ghz 512 Mb Ram...
I am stuck on the boot up screen and wont let me reset
Pull battery. or
search for cmd.com
execute cmd.com
type in " shutdown /s " to shutdown the computer at command prompt
type in " shutdown /r " to reboot the computer at command prompt
Jan 21, 2014 | Proscan Recertified - PLT8031 4GB NAND...
How to reset my apple mac i5 2.7GHz 4GB
Resetting the Firmware on an Apple Intel Based Macbook Pro/Mac Mini/Imac/xServ
As soon as you press the power button hold down all the following keys on the keyboard;
CMD, Option, P, R
This will result in the startup chime sounding twice instead of once.
[CMD is the key left of the spacebar, Option is the key left of CMD]
This should fix most POST/Display/Firmware faults if no serious hardware fault is present
Hope this helps! :)
Sep 29, 2012 | Computers & Internet
On startup, my power book pro 17" will not open
Hold down Cmd-S as you start it up. You'll get 'single user mode', which is text only. See if there are any obviously bad error messages.
At some point you will hopefully get to a command prompt. You'll see a message telling you which commands to type to mount the filesystem and check for errors - follow that.
You could also type the following to look at the last 50 lines of the log file - perhaps there's a clue to the error in there: tail -50 /var/log/system.log
Restart with shutdown -r now
This may not fix your problem but it might tell you where the problem lies.
Otherwise you can boot from your installation disc and restore from that. You'll then need to get all your documents etc. from your backup.
Jan 12, 2011 | Apple MacBook Pro Notebook
How to open bios setup in apple mac book
Macs do not have BIOS. They have OpenFirmware.
To access hold down CMD-OPT-O-F during bootup, that is the letter O not zero.
You will get a command prompt 0 >
Do a Google search for OpenFirmware to find out all the commands you can use at the prompt.
Dec 08, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When I start my computer I can't get past the password becuase I forgot it and I dont have a disk can you help me
Try this :-
Creating a new Admin on Mac Os X: Here's how to reset your OS X password without an OS X CD.
1. Reboot 2. Hold apple key + s key down after you hear the chime. (command + s on newer Macs) 3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
mount -uw / rm /var/db/.AppleSetupDone shutdown -h now
4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again!
Apple stores wont reset it for you. Computer shops may have charged you $50 to $200 trying to reinstall the Mac.
Nov 16, 2010 | Apple iMac OS 9.1
The prompt for shutdown comes up repeatedly
try starting up with the system/install disk, select language then at the top there is utilities, select disc utility and repair first then repair permissions. Then select startup disc and restart. If this fails then do an archive and install.
Oct 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Windows XP
www.apple.com
This should fix all of your problems.
Jul 15, 2009 | E-Machines eMachines Desktop PC
I cant unlock my apple laptop
first, reboot your computer. then, hold down the apple key and the "s" key after you have heard the chime. when you get the text prompt enter these terminal commands to make a new administrator account (be sure to hit return or enter after each line):
  • mount -uw /
  • rm /var/db/.AppleSetupDone
  • shutdown -h now
after rebooting your computer, you should have a new administrator account. you can then proceed to delete the old one and you're set
hope this helps ;-)
Mar 29, 2009 | Apple aluminum 13-inch MacBook laptop-...
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Apple PowerBook G4 Mac Notebook Logo
219 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
