Question about Logic Soundlab Car Audio & Video
I am installing a logic sound lab cd420I. What color is the memory wire that needs to stay hot
Need to find hot wire for installing radio in 1995 Mustang
get i cheap test light there should be one with 12 volts all the time that should be the memory for radio then turn on ignition to find 12 volts for radio when ignition switch is on black is usually ground there might be a pink or purple or blue wire for power antenna if needed then trace speaker wires if yo dont know on new radio get a manual
Mar 27, 2014 | Shoprider Health & Beauty
06 Pontiac g6 stereo has two different models a regular one and a monsoon hence two different wiring harnesses I have the regular harness and the monsoon stereo Is there a way to make it work the volu
if you can match the wiring funtions of each unit up one wire at a time.. then check before installing for operation..you have4 speakers (normally) a memory wire (on all the time for clock and stations) power wire(hot with key on) ground wire and antenna lead.. good luck..wire colors will not match but functions need to..(what each wire is for)
Dec 28, 2012 | Cars & Trucks
I hook up a jvc kd-s16 and it will not keep the memory of the stations can you help
The yellow wire is the constant 12+V.
It has to be hooked up to a constant battery source.
If you did not install an aftermarket wiring harness consult
http://www.installdr.com/QuickWiring.html to find the constant 12+V wire color code in your dash.
If you unhook your battery, you can splice into the cigarette lighter hot wire to keep the constant memory of stations and clock time.
Aug 01, 2010 | JVC AM FM CD DET FACE CAR STEREO
Bought a used 5300 printer and installed new color and black cartridges. Cannot get the black to print at all. Some color but very faint. What is the problem
You need to clean the "ink tops" in the printer.
Better have the lab do it.
If you decide not to , just use warm-hot water & simple kitchen soap.
Let it dry for at least a day before plugin it in the power back.
Sharon
Feb 03, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Installing radio in 85 mercedes-benz
there is no amplifier. you just need to find the memory wire that is hot all the time and the 2 wires that are hot with the key on. One is for radio operation and the other is for antenna operation. The speaker power is supplied through the fader switch in the center console and the switch is powered by the head unit. Just hook up your circuit 30 and your 2 circuit 15 with a ground and run you speaker wires to the head unit or if you are installing an amp from the wires from the fader switch. That switch can be popped out with a flat blade screw driver, Hopefully i have been helpful
May 28, 2009 | 1985 Mercedes-Benz 190
Loss of sound after i start the angine
red - switched power (hot when key is on)
yellow - constant power (hot at all times - depending on the vehicle, i've used a direct battery connection, but isn't recommended)
black - ground
blue - power antenna or amplifier 'REM' wire
the other's, i'm working off of old memory....
purple - rear right
green - rear left
white - front right
gray - front left
wires with black stripes are ground, and without are hot
- if you're working on an older car, it sounds like your red and yellow are connected to the same power source. if this is the case, the time will always be resetting.
- if it's a newer vehicle, AND the time is not resetting, the red wire is connected to the wrong source. if the time and stations stay programmed after it shuts off, the yellow wire is correct.
Feb 03, 2009 | Sony MDX-CA580 MiniDisc Player
Stereo wireing
go to advanced auto parts and buy a connector for your car. just go and give them year, model and make and when you get it connect the same color wires from the stereo to the stereo harness. all of the colors are the same.
Jan 07, 2009 | 1998 Oldsmobile Intrigue
I need a wiring diagram on my 1992 toyoata celica gt coupe for the stereo wires. the colors are different and i need to figure out what each is. thank you very much.
92 toyota celica gt - w/o cd player schematic is :
light green = right front tweeter + right front speaker
pink = left front speaker + left front speaker
grey = 15 amp fuse / hot in acc or on posistion
blue/yellow = dome light / hot all times
blue = right front speaker + right front tweeter
violet = left front speaker + left front tweeter
brown = ground
black/red = power antanna
pink/blue = power antanna
red = right rear speaker
black = left rear speaker
white = right rear speaker
yellow = left rear speaker
this was for the WITHOUT cd player , hope thats the model you have , since you didnt specify . repost if you need with the cd player
Dec 24, 2008 | 1992 Toyota Celica
Car Audio & Video Logo
24 people viewed this question
Top Logic Soundlab Car Audio & Video Experts
xxxxxx xxx
Are you a Logic Soundlab Car Audio and Video Expert? Answer questions, earn points and help others
