How hard is it to change a LAN card in a desktop computer
  • 2,841 Answers
Very easy. Remove the power cord from the computer. Now remove the side panel off the computer. On the very back of the computer where the LAN card connection is you will see a phillips screw holding it in place. Remove that screw and then from inside the computer pull the card up and out of the slot it is in. Place the new card in and press firmly to seat it. Replace the screw on the back, and the side panel. Plug the power back in and you are done.
Posted on Sep 01, 2010
  • 776 Answers
Please follow instructions as provided in the article below:
http://www.computerhope.com/issues/ch000418.htm
http://www.ehow.com/how_5415698_change-nic-card-pc.html
No internet connection with lan on my dell dimension 4700 i up dated drivers but no luck. wy wireless works but no hard wired. i just installed win 7.
Kindly check Device Manager if the driver has been successfully installed. Check if there is a bang (exclamation mark) under Network. Make sure that the downloaded driver is compatible with Windows 7. If this has been done, 1. Go to BIOS and see if LAN has been disabled 2. check if there is a blinking light on the LAN port on your computer. If there isn't, then I guess you may need to change your LAN card.
Sep 01, 2013 | Dell Dimension E521 (D10E16) PC Desktop
Lan card not found
Please, follow the instructions below, and reply with the status of your LAN driver:
Start>Control Panel>System & Security>Device Manager>Network Adapters...
Find your LAN card and see if it has a question mark by it. Try to right-click on it and update the driver. If that doesn't work, uninstall the driver, reboot your computer, and re-install the driver.
Also, let me know what model computer your using and whether or not its Windows XP..
Thank you!
Nov 21, 2012 | HP xw6200 PC Desktop
HOW TO INSTALL DYNEX DESKTOP 10/100 MBPS PCI NETWORK CARD
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
Used to run wired desktop and wireless laptop off a Netgear DGN2000. No problems. Just changed the desktop for a new one. The laptop continues to work fine but can't get internet on new wired-in...
Check to see if the LAN card is enabled and working. If not install the LAN card driver.
If the LAN driver is working then go to Control Panel - Network Connections - right click on the LAN card then click on Properties, then check the TCP/IP settings of the LAN card, Tick Obtain an IP address automatically and tick Obtain an DNS server address automatically.
Then you will be able to connect to the Internet.
Jun 11, 2011 | NetGear DGN2000-100NAS Router
How do you connect to the internet on a sony pcv-120 since i dont see a ethernet plug in anywhere
It is possible that your desktop does not have a LAN card installed.
Go into the Control Panel - System - Hardware - Device Manager and click on Network Adapters and if there isn't a LAN adapter then there isn't one installed.
Then you need to purchase a LAN card and install it in your desktop computer.
Dec 21, 2010 | Sony VAIO PCV-J120 PC Desktop
I have a IBM thinkcenter 8123 model. I can't install lan due to lac of suitable driver! pls help me!
Go into the bios on your computer and shut down the onboard LAN, find a 3com or realtek LAN card and install it, windows has the drivers build in for most 3com cards, then you go to IBM site, download the drivers you need for the onboard LAN connection, remove the 3com card let the computer boot up, and when it asks for the driver point it to where you downloaded the drivers for the onboard LAN.
Jun 18, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
Not reading wireless connection
The wireless router needs its wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 15, 2009 | E-Machines T5048 (7136) PC Desktop
My internet provider says i need a lan card what is this? and how do i get it
You can buy Lan card at any computer store, just give them the spacification of your computer and model, they will give you the Lan card compatible to your computer.
Lan card is a board that you will attach to *********** board, it have an connector for you lan cable so that you can connect to a modem to connect to the internet.
Nov 04, 2009 | Dell Computers & Internet
Transfering data from one desktop to another through LAN connection
you have to put the cable in the ethernet card (or network card) it looks like telephone connector ( it will be big in size)
May 31, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
