Question about Avanti DER24CSS-1 Electric Kitchen Range
The oven isn't heating...light goes on when knob is turned on, but, it does not get hot. Stove top burners work, so, there is no problem with the fuse. I'm thinking it's the element, but, it looks fine to the naked eye. Also, not sure it's so easy to change. Pls advise...Thanks- Debbie Allen Debra.allen@gmail.com
  • Avanti Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Sep 02, 2010
On my electric stove, one of the burner caught on fire, and now the indicator light stays on even after the stove is turned off
If the light remains on, that would indicate the circuit was damaged. The light goes on when the circuit is complete. This usually happens when the burner gets hot. If it caught fire, then the stove is registering it as hot all the time.
Elisa Jed ' http://www.atlasappliances.com/en/pg-kitchen-appliances
Jul 07, 2014 | General Electric Stove/Oven/Range Chrome...
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
I have a Hotpoint RGB745 when i turn the stove on it never gets out of pre heat mode. oven is warm but not hot. top burners work fine
The stove knobs won't turn on the oven. If you've already checked the igniter, take apart the top and look for loose wires. My husband found a loose one going to the control board, tightened it and now things seem to be working.
Dec 04, 2010 | Hotpoint RGB745 Gas Kitchen Range
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Avanti DER24CSS-1 Electric Kitchen Range Logo
196 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
