Question about Apple iBook G3 Mac Notebook
G3 Doesn't power up
Yesterday I received a cheap second hand G3 from someone on ebay who sold it as untested. It powered up fine although switched off quickly when the battery ran out. When I put the machine on charge it worked fine (although with a patchy screen).
I switched it off and left it to charge over night. When I came back to it this morning the DC lead was still amber although when you press the button on the battery all four lights illuinate. The computer doesn't power up at all, either under battery or mains power.
I can't work out what's changed over night. I have my girlfriends work computer which is identical so I can try swapping parts to work out what's wrong.
Has anyone come across this before?
    Genius:
  • 1,019 Answers
I,d check that the laptop isn,t in Standby or powersave Mode.
Check the Ram, and re-seat if necessary.
Try the laptop without The Battery.
Regards Mike @ compurepair.
Posted on May 10, 2008
Sony dab fc7 wont power on
Two thing here.
#one the internal fuse has blown unlikely as the standby light is powered.
Two the power supply unit or switch is faulty.
get some one electrical component with the unit unpluged open the case and check any internal fuses have not blown.
Two check capacities on the power board these are large cylindrical shaped objects. These can dry out and or exploded if faulty relatively cheap to replace.
Second check the power switch actual powers the unit again someone with a multi meter and electrical compertent.
It is probably worth replacing either a capacity or switch anything else may prove false economy
I have replaced power board on other units but to be honest unless the unit was very expensive I would buy new
Dec 06, 2013 | Audio Players & Recorders
Where can I buy an antique s candle holder? I hate all this modern stuff.
Check out this site, although it's not cheap prices http://www.paulmaddenantiques.com/ancaho.html or you could always try looking on ebay for some good second hand deals.
Feb 07, 2013 | Crafts & Hobbies
My yamaha yamaha_rx-v457 does not switches on
Hello, welcome to Fixya!
Your receiver is having a power fault because it is not switching on. The receiver might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the receiver, it goes straight into the power supply board which then circulates the current into the unit. So if the receiver doesn't power on, the first thing is to make sure there is power entering into the receiver.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Dec 14, 2011 | Yamaha RX-V457 Receiver
I bought this yesterday and the moter in the back that balences it stopped working... how do i fix it
will need multitester to see if motor is receiving power when you use the forward stick. if the motor is receiving power then the motor will need replacing. Motor slids in and out. Can get motors on ebay quite cheap.
Jul 28, 2010 | SYMA Toys industrial New Syma S107 Mini...
Yamaha RX-V793, Turn it on, 2 sec later turns off
Good luck.
Nov 29, 2009 | Yamaha RX-V793
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Power went out for a brief minute yesterday. My
vwhat is vijay maruti bomble (civil engineer) mobile no.
Aug 20, 2009 | Kitchen Ranges
HP Media Center does not power on
Sounds like your power supply has took a dive.
You can replace it yourself for really cheap $20-$50 or have a local repair shop or someone from craigslist for about $60-100.
It's really just four screws to remove the power supply and then you just put all the power connectors back. It's NOT hard if you just take your time and pay attention to what you are doing.
Best of luck!
Jun 13, 2009 | HP Media Center m7250n (ED842AA) PC...
Power
Replace the power switch. A fairly standard switch type. You may get one off ebay or similar site. If push came to shove, you could just replace the power input assy.
Aug 13, 2007 | HP LaserJet 4L Printer
Apple iBook G3 Mac Notebook Logo
104 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
