What does error code E000001-0000 on a Canon IR5000 copier mean
  • 776 Answers
The error code is much more likely to be E001, this is a fuser type fault. You should be able reset it in service mode. (copier, Funtion, Clear, error, turn m/c off then back on)
As the issue is a fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Posted on Sep 01, 2010
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
User manual or User Guide of iR325s and iR5000/6000
give me your email and ill try to get some manual for you
Mar 11, 2010 | Canon imageRUNNER 5000 Copier
I have problem with IR5000 code error E000020-0000
Hello, All I can tell you is exactly what the code means. However, I would be inclined to think that some one has been working on you device reatively recently because....... it means that the connector to the toner/ developer hopper is disconnected. But after that, .....it gats ugly. For some reason the copier cannot determine the toner level in the toner hopper. That means that the toner level sensor in the toner hopper is bad, or the DC controller(main board) is bad or is not being supplied with correct info. I will gladly help u further as u inspect the situation.
Mar 10, 2010 | Canon imageRUNNER 5000 Copier
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Error code E000245-0010
KABRaji, Your copier print board is faulty or some loose wiring. also posible if some fault in counter pcb
Jun 11, 2009 | Canon imageRUNNER 5000 Copier
CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Mar 27, 2009 | Canon imageRUNNER 5000 Copier
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
798 people viewed this question
k24674
jasbo
jasbo
