Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Minn kota endura 30 has been running fine but today with only about 30 min use stopped and will not run - recharged battery - took only 20 min - was not discharged - hooked up to motor - nothing what is wrong - this motor is about one year old and only used on a small pond 6' boat jack botteron - ossian in
  • 1,606 Answers
First is check for loose connections on cables and so on. Hopefully it is just a bad hookup. Loose wire, corrosion, nice easy stuff to find and fix.
If it just stopped and after that point you didn't see any life at all then I would think the controller board inside had failed. This controls or varies the speed of the motor. Unfortunetly thats going to be a shop job.
The good news is you should have a two year warrenty on that. So if you contact minnkota they should tell you where to drop it off to get fixed or replaced. The minnkota web page is www.minnkotamotors.com You can look at your warrenty and supoprt info from there.
and if you are in Ossian then the closest dealer they list is
united vaccuum
1011 e coliseum blvd
fort wayne
, IN
46805
Phone: 260-484-7162
cour6229@comcast.net
10am-5:30pm m-f, 10am-5pm sat
That should get you fixed up.
Posted on Sep 02, 2010
What spec battery is the best for the Minn Kota 40 Endura trolling motor?
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
May 19, 2011 | Minn Kota Endura 40 Transom Mount Trolling...
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Overheated Minn Kota Endura28
This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Trolling Motor will not run
Hi!
For starters, here is a schematic:
Endura 30
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Best of luck!
Mike
Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
165 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
