Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
External Hard Drive not showing on computer, was listed as F DRIVE now it's not there. Plugged in and shownig power but not listed.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
My HDD 551 suddenly does not work with my windows 7
Check the following
  • With the drive plugged in on powered on place your hand on it should be able to feel it vibrating (if no its not getting power or dead)
  • If power and vibrating put your ear to the drive (repeating and squealing are bad, crunching sound is generally ok)
  • With the drive plugged in and it sounds ok and it's vibrating[platters are spinning] right click on "Computer"/"My Computer" select manage > Disk Management, locate your drive if it is listed try to initialize it
  1. Right Click drive, properties, hardware tab, select drive, properties, volume tab and click populate
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
Aug 31, 2011 | PQI 320GB H551 USB 20 Turbo Boost External...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
Computer does not regognise the external hard drive. it does not say that it is there, even though it is plugged in. What can i do i have tried unplugging and replugging. It used to be called F driveCan...
First, it is important to know what operating system you have, and you have all the drivers installed, if Windows Vista, XP or OSX, in any case, you must have operating system updated with the latest version of ServicePac, usually this solves the recognition external devices.
Dec 01, 2009 | Western Digital Elements powered by WD 320...
Hard drive needs to show as f instead of g on computer when plugged into usb
Connect your harddrive to computer then when you power up the computer press F8 key then enter in safe mode.
Then it fix messup .
If still not show as G then right click on my computer icon then click on manage.
Then click on storage->removable storage or disk management there you can see your drive icon right click on it then change drive letter.
Nov 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My WD 250 GB drive, when plugged in initially, spins clicks and then goes silent. I believe that a virus has been moved to it and opened via an MP3 file my daughter down loaded. how can I get it to power...
Does it show up when you open my computer? If not, try unplugging it and plug it back in. Then check my computer again, if its not listed then it has probably died. Check the WD website for warranty info. I see allot of problems with WD external drives. Be it a bad hard drive, control boards, and or faulty power supplies. If it does show up you should be able to scan it. Good luck.
Aug 19, 2009 | Western Digital My Book Essential 1TB...
I have an Elements 250G working fine until my computor started to wear out, and wouldn't show that my hard drive was there, I now have another computor, plugged in Hard drive, and the computor says it's...
If the disk is recognized, you can go to the Disk Management console (right-click My Computer and select Manage in the popup menu). There the disk should be listed, and you can check if it is partitioned and formatted.
Also check the drive letter assignment for the disk, if there is a conflict with some other device one of both will not show. You can simply change the drive letter.
More tips on this: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jules
Jul 19, 2009 | Western Digital 250GB ELEMENTS EXTERNAL...
No detection with external hard drive SP-U35/500
Change out ur BIOS settings about External drives.
Bye
Mar 22, 2009 | Computers & Internet
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
80 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
