Question about Sony SLV-D300P DVD Player/VCR
When I load a DVD into my SLV-D350P DVD Player/Video Cassette Recorder, it spins momentarily and then stops with a message that the DVD cannot be read. However, I purchased a CD/DVD cleaner at a retail store, placed it into the DVD drive and, it did read the cleaner CD that went through a dry cleaning process. After completion of the cleaning process, the unit would still not read any DVDs. I am not certain what to do at this point. Do you have any suggestions?
techman
  • 3130 Answers
SOURCE: Sony SLV-D350P DVD/VCR
try cleaning the lens as if its been sitting it could have a layer dust or dirt film that may need to be taken apart to clean properly. Good luck
Posted on May 29, 2006
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
  • 59 Answers
SOURCE: code for sony dvd combo
I found this on a forum on line but it doesn't look promising. One person said this worked and one other said it didn't - only two entries though.
1)No disc & tray closed
2)Once the "Insert disk" message in the top-left side of the screen appears, press (in the remote) the Subtitle key and continue with 29334 in sequence.
3)A number(1 in my case)appears in the top-left side of the screen. I believe that this number represents the region code of your DVD equip.
4)Change the number by typing number 0.
5)To save press the "open/close" key and then Enter (small one at the top. Not the big one at the bottom!!)
6)Now check if it works.
NOTE: Other way to check if the change was successful, is to repeat steps 1 to 2. You should then see a 0 in top-left side of the screen.
Posted on Aug 22, 2008
preachw996
  • 1179 Answers
SOURCE: DVDs on my Sony SLV-D350P DVD/VHS player play in black and white
First try a good quality dvd cleaner. If that does not cure the problem then the video cable may have went bad. I had a system that the cables were never touched & after a few years it needed replaced in order to get my picture back. Hope this helps & please take a moment to rate my answer. Thanks.
Posted on Feb 08, 2009
ciak2009
  • 5 Answers
SOURCE: Sony SLV-D350P dvd/vhs player won't play most DVDs
Try buying a DVD Player disk drive cleaner.
Posted on Feb 22, 2009
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
DVD side of SLV-D350P does not play DVD. Shows loading and Sony logo screen. Pressing any buttons on remote gets me a red circle with a line thru it in upper r/hand corner.
Open the DVD door/drawer and let the warm air get to it. Condensation which can form is dried and the DVD worked again. Leave open for 3 to 4 hours.
Dec 27, 2009 | Sony SLV-D350P DVD Player/VCR
I lost the remote control for the Sony SLV-D350P. Where can I get another one and how much is it?
Required Remote Control is available in Sony Accessories Store for $30 under following part number..
988506120... RMT-V501C REMOTE COMMANDER
Thanks.
Dec 18, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D350P DVD/VHS Combo
No, most DVD players sold in regular store are for R1 only, you need to look online for multiregion player.
Nov 01, 2009 | Sony SLV-D350P DVD Player/VCR
Sony SLV-350P stopped working
q marca de control puedo usar, porq el original no lo tengo
Oct 11, 2009 | Sony SLV-D350P DVD Player/VCR
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
May 29, 2006 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D300P DVD Player/VCR Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
