Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Nope still no luck
Unfortunately that didn't work either, still same problem. I've tried it in both my Home and work pc (both of which run on Win XP) and in different usb ports, both front panel and rear ports, no luck.
  • 1 more comment
  • Charrgrill May 10, 2008
    Well the thing is that both pc's detect it, they say that new hardware has been found and is installed and ready to use. But the drive isn't assigned a drive letter and so isn't shown in My Computer - it just says that Mass Storage Device is connected in the pop-up at the bottom of the screen, no name or letter so I can't access it.
  • Charrgrill May 12, 2008
    I'll try it and let you know but I got a hold of a Westrn Digital drive diagnostic and repair tool from their website and it didn't even get passed the first test saying that there is a cable detect error. I tried plugging the drive into different USB ports (front and back) as well as using different a cable all that accomplished was a faint clicking noise from the drive which i'm pretty sure it's never done and seem to remember means the reading arm in the drive is stuffed or something. Which is annoying 'cos I know for a fact I didn't drop or damage the device between work and home on that day, yet it worked fine in the morning and packed up that night. So I'm going to contact Western Digital and see if I can get them to replace it/explain the problem in more detail.
    Anyway, thanks very much for your help but I guess I'm just going to have to settle for losing the data and getting a new drive, if they don't think that I've voided the Warranty somehow.
    Cheers
  • Mark Gil
    Mark Gil May 11, 2010
    So now your portable hard drive is not detected by the 2 pc that you have tried right? there's no pop up about a found new hardware when you connect it to a usb port?
    Problem Solver:
  • 8 Answers
Try this--but it will delete anything you might have saved already on the Simpletech
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Posted on Jun 05, 2008
  • 6,487 Answers
Ok try this Right click on your desktop>click NEW>click Shortcut then type there E: the click OK.
Posted on May 10, 2008
  • Mark Gil
    Mark Gil May 12, 2008
    Yup that will be better call them for the replacement.
Plustek Optipro 9636T - working under Windows 7.
If you scanner only has Win XP drivers, then you have only two choices as those drivers wont work on WIN 7. One is to buy a new scanner, as you have already suggested. The other is to create a virtual machine, load WIN XP onto it, and then install the scanner drivers on the virtual machine. This should work fine as I do it for a piece of software that only works on WIN XP, however it is a bit of a inconvenience to use.
Aug 20, 2017 | Plustek OpticPro 9636T Flatbed Scanner
After updating Iolo Sys. Mech 11, message said System Mechanis Service was missing. aftersearching for answer, was told my Background Intelligence Transfer System was missing from Win XP Pro startup....
Right click on My Computer, choose Manage. Window opens, choose Services and Applications/Services. Look for Background Intelligent Transfer Services in the middle. Right click, choose Properties. Make it say, Automatic (delayed). Choose Apply. If it is not already running, click Start. Choose OK/Close or whatever. Close the Manage window. Reboot the computer. Good luck.
Jul 16, 2017 | Microsoft Windows XP Professional SP3 for...
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Sep 15, 2011 | Mindscape PrintMaster Premier 7.0
I downgraded from vista to xp and now i need a sound driver compatible for my gateway:w34oui
This is another tough one.
Since GW does not have Win XP drivers available for your system, it will be difficult to find a sound driver that will work. You could try to use the Vista driver, but I would be skeptical that it will work to use that driver because of the way that sounds are processed in Vista/Win 7.
You didn't mention why you did the downgrade, but if it was performance related, Win 7 should work fine with your system. If there was a certain program etc., that you need, there is another option.
There are many USB soundcards that will will work well with Win XP, and they should not have the XP problem since their hardware is designed to work with XP. Note: If you go this route, make sure you choose one that is Win XP compatible. One other thing on this option, though. Your internal speakers may not route sound through the USB soundcard, which would mean then that you would need external speakers to get sound. I understand that may be a deal-breaker, which is why I would (unless you specifically need XP) either go back to Vista or upgrade to Win 7. Some version of Win 7 feature "XP mode" which allows you to run programs in a virtual Win XP environment. I have not had perfect luck getting XP programs to work, but it's worth a try.
May 25, 2011 | Computers & Internet
Victim of software counterfeiting
I am glad to HELP YOU!
So - if I got it right - you've bought the installation disk and you didn't pass the validation on the manufacturer's website or so... Or you don't have the right product key to fully install it...
You're not the only one in such a situation.
Unfortunately there's no other solution but to go to a certified store/online store and to buy THE REAL SOFTWARE. For the version [counterfeited...!] that you've bought nobody will be able to get you the right key. Even if you will report the situation to the manufacturer...!
Try to return the CD/DVD to the seller and if you paid for it ask for a full reimbursement.
GOOD LUCK!
! Windows Tips
Apr 25, 2011 | Microsoft Windows XP Professional for PC
Can't load windows xp onto my dell c610
when you are trying to install xp what method are you using
how are you doing it
Jan 20, 2009 | Dell Latitude D600 Notebook
Audio driver not working
The Audio driver has little to do with the OS (Operating System- windows) It is a board fixture or a hardware addition, and therefore requires teh drivers as supplied by the manufacturer of the equipment. Find out the name of the component or the motherboard and either google it for its drivers or go to the manufactures website and look under support for the drivers you need.
By the way, its not very clever to make abreviations in two letter words!
Bluray
Nov 19, 2008 | Microsoft Windows XP Professional With...
NT4 sees XP Pro in network neighborhood, but access denied
If you arent too worried about security since it is at home, enable the guest account on the windows XP machine, also disable the firewall on the XP machine ( it is on by default )
let me know
Oct 29, 2008 | IBM NetVista PC Desktop
No OS FOUND on my Pavilion a1600n (preinstalled Win XP) can I install Win XP Home Edition I bought. My recovery disk will not work.
boot with win xp setup disk.
set first boot devic as cd drive then insert win xp disk into it.
then follow wthe procedure .try to repair os win xp .if it is not found bye setup go to recovery console run this command: CHKDSK /r
then wait untill cmd probmpt.
ten u can repair win xp
Sep 15, 2008 | Computers & Internet
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
52 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
