Question about Frigidaire Affinity AEQ6000WH Dryer
I have a Frigidaire Affinity dryer that shows power but when I press start it has a humming noise and wont spin.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Mywashermakesahummingnosieandwontspin
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF6000F, is making a humming noise and will not spin. If your load is too small, this can cause your washer to not spin. Add a couple of similar items to help balance the load. On the other side, your washer could be overloaded. Try taking out some items and restarting the cycle. If neither of these is effective, try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Affinity ATF6000F Front Load...
Why my frigidaire affinity wont spin
Good Afternoon Iliana, thank you for allowing me to assist you!
If your washer does not spin, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Dec 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Affinity washer stopped working. When i start the cycle it makes a loud humming noise, but no water goes in, and it starts spinning for a few minutes, then the time goes from 1hr, to 3 m
Possible that the inlet valve is faulty. please measure the voltage on the inlet when the washer is switched on , if there is no voltage then the controller is faulty. If voltage is present then the inlet valve has failed.
Jun 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryer making a buzzing noise
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 13, 2010 | Frigidaire Electric Dryer
Frigidaire affinity dryer has power but won't start up the cycle
Hi!!! you have a problem with the thermal fuze change it and you will be okay..
Jan 21, 2009 | Frigidaire Dryers
Frigidaire Affinity AEQ6000WH Dryer Logo
342 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
