Question about Kenmore Refrigerators
Model #795.78302.804 Ser#903MRKU26909 just a year old and the sealing on side by side doors tearing,,,already did parafin thing as recommended,,any answers,,?
  • 1073 Answers
SOURCE: Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
Posted on May 17, 2008
cosatto
  • 29 Answers
SOURCE: my refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
Posted on Dec 10, 2008
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
SOURCE: I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Posted on Jun 28, 2010
SOURCE: The door seems to be warped or tweaked in some way
Your fridge is not level. If you level it you will find that the door was fine , it was the fridge that was tweaked because it was not level and sitting correctly. Use a level, shims, and/or the adjustment screws on the bottom.
Posted on Jul 28, 2010
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Feb 19, 2014 | Maytag Washing Machines
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
Dishwasher door leaks on the left side at the first part of the wash cycle. Seems like it seals itself as it runs and gets hotter. Cannot see any wear or tear on the door seal (2 years old). will replace,...
Hi there... Try the simple things first. Quite often Fridges and dishwashers (with flat front seals) will start to leak if the body of the unit is distorted. This frequently happens if the supporting feet are not adjusted properly when setting up the unit in the first place. After a while the cabinet will begin to 'sink' in one corner which distorts the flatness of the whole front of the frame, allowing leaks. Try cranking up the foot nearest the leaking seal and see if it makes the leak better or worse. If worse, then crank up the opposite foot. Good luck.
Nov 24, 2017 | Whirlpool Dishwashers
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Elite HE3T door seal tear
tear may be from pulling something across it with sharp edges..to replace seall not major job front part of seal held in place with spring ..remove and pull boot away from front edge inlet tub slides out of boot opening rear held in place with LARGE screw clamp a little patience is usually all that's needed ..did 2 today
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
The freezer will not get cold, i replaced the defrost timer and the t-stat inside the freezer, and it keeps icing up, the heating element does work, the unit is only 2 years old
Turning it down a 1/2 to 1 knotch id try, the Whirlpool recommended is 0-5 degrees in freezer, im sure you have already cleaned coils.
So my last recommendation is the door. Ensure is closing and sealing. Sometimes the hinges wear out and the door sags, seals but sags causing humidity to get in and freeze up.
Try slipping a piece of paper between seal and door, if it goes right in its sagging, just make sure you check the whole area this way.
May 02, 2008 | Refrigerators
16 year old whirlpool dishwasher model no. DU8950XY-0
Sounds like it is a bad door seal. Recommend replacing the door seal and making sure the door is shutting square and not bent.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 25, 2017 | Whirlpool Dishwashers
Refrigerators Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
