Question about HP Photosmart C7250 All-In-One Thermal Printer
My printer only has two scan options - HP Photosmart C7250 All-In-One Thermal Printer
    President:
  • 2,678 Answers
Would that be scan and don't scan?
Posted on Sep 01, 2010
Had been scanning pictures into computer and now i
First let us remove the No Scan Option.
First try to Scan from HP director or HP Solution Center.
If it is scanning, perform the steps given below to resolve the issue.
Open HP solution center/HP Director:
Click on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
Jun 02, 2010 | HP Photosmart 3210 All-In-One InkJet...
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
A Menu Appears.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan a picture to e-mail? new officejet 6500
On the printer itself it says no scan option because there is no option attached from the solution center.
That means the mapping between the scanner and the software on the computer does not exist which results in :-
you will be able to scan from the solution center on the computer but not from the printer itself.
To solve this problem please follow the following document according to your window OS.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01798218&cc=us&lc=en&dlc=en&product=3418705
You must set up a list of potential scan destinations in order to start scans from the printer.
To do that please follow the
( Solution two: Set up the destination list )
In the Document link Provided.
I am sure if you follow this document it will work.
Once you Update the device with the list of scan options. you will be able to see the scan to e-mail option on the printer.
( Note :- remember to send through the scan to e-mail option directly. You must have Microsoft outlook or outlook express configured on the computer Else it will not work. )
May 05, 2010 | HP OfficeJet 6210 All-In-One InkJet...
"no scan options"
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP Photosmart C6280 Printer
How do I scan something from my wireless printer to my computer
There are two options.
Option 1
Make sure your computer is on. Insert the document you want to scan. Click on the scan button on the printer. The document will automatically be scanned and saved in your computer in mydocument under mypicture->my scans folder.
Option 2
Insert the document which you want to scan in the scanner. From your computer invoke HP Solutions Center. There you will see options to scan the document.
Please note for both the options you must have installed all the softwares which came with your printer.
Nov 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
No scan options say refer to device documention to trouble shoot
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
NO Scan Options
Try ths:
the resolution:
Click on Settings
Click on Update;
Regards Soumajit
Feb 18, 2009 | HP Officejet 7210 All-In-One InkJet...
Scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Aug 31, 2008 | HP Photosmart C6280 Printer
HP Photosmart C5280 Printer -scanning
Try ths:
Click on Settings
Click on Update;
Regards Soumajit
Jul 20, 2008 | HP Photosmart C5280 Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
