Question about Powerline TRENDnet TPL-101U USB Adapter (NETPWLTPL101U) Network Adapter
We cannot setup our tpl 101u trendnet powerline on our new computer running on windows 7, how can we solve?
No signal
try in a different outlet on same curcit.
Mar 18, 2014 | Trendnet TPL-401E Up to 500Mbps Powerline...
Windows 7 compatabilty
Hello you can try the software here from dlink:
http://www.dlink.com/us/en/support/product/dhp-301-powerline-hd-network-starter-kit
Maybe it will work in 32 bit but not in 64.
I guees you have to buy a new kit compatible with windows 7.
Good luck
Oct 25, 2012 | D-Link PowerLine HD Ethernet Kit (DHP301)...
I need a driver for a trendnet tu2-et100. I'm running Windows 7 OS.
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
Aug 21, 2012 | Trendware TRENDnet TU2 ET100 network...
How do i hook the desktop up to wireless internet
I bought a Trendnet USB mini wireless adapter and it works good, I little trying at first to set up but it works good. Try Compusa or maybe BBuy.
Mar 10, 2012 | Dell Inspiron 531s Desktop Computer
I am trying to use a trendnet TPL-302E2K But my OS is windows 7 home premium The utility for TPL-302E2K uses Netframework 1.1 which seems to be incompatible with Win7 I tried downloading the most...
I don't think you can. I had a similar problem with a office type program and finally had to get a new version of it, of which I didn't know existed. I guess my other question is that didn't it state that it wouldn't work with anything lower than Win10?
Jan 26, 2018 | Trendware TPL302E2K Network Adapter
When i installing adobe photoshop cs2 , there is error 1311 so how can i solve this
Your CD might be damaged in someway.
You can try this to solve it.
1. Copy the content from the CD over to you computer.
2. Run the setup you just copied to your computer. (if you have Windows 7 or Windows Vista you will have to run the setup as administrator.)
That should fix your problem.
Mar 07, 2011 | Adobe Photoshop CS2 for PC
How can I reset my TPL 202E
According to the TrendNet website you need to press the reset button and hold it for 15 seconds.
Here's a link to their site:
http://www.trendnet.com/kb/kbp_showproduct.asp?ToDo=browse&catId=510
From this link you can access alot of info on this unit (manuals, drivers, support, etc)
I hope this helps.
Best of luck!!
Mar 03, 2011 | Trendnet TPL-202E Up to 85Mbps Powerline...
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Computers & Internet Logo
54 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Tom Chichester
Rob Woolcock
Rob Woolcock
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
