Question about Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10
I just replaced the lamp (XL 2400) but the tv keeps sutting off. It was doing this with the old lamp. I thought I needed to replace the lamp due to a pop-up menu on the tv saying the lamp was nearing the end and needed replacement. I thought replacing the lamp would take care of the problem---but I guess not. Please help!!!
  • Sony Master
  • 17,130 Answers
The fault is in the power section ,unless you can notice a visible damage of the mains capacitor or related circuit in the SMPS( try to replace main filter capactiors , secondary filters) the possibility that the current limiter is working to shut off is a possibility.
The power supply unit can be the main suspect and to check it on the circuit will be difficult as you will need to work and put it back again which is not very good for the main board. so if a spare one can be got to test to confirm, you can get the SMPS replaced.
Check also the optocoupler , the main SM driver.
Posted on Sep 02, 2010
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Tip
Sony DLP Lamp XL-2400 How-To Replacement Guide. For Part Number: Sony Lamp...
For Part Number: Sony Lamp XL-2400 ( Sealed replacement lamp for televisions, SMALL & SEALED ).
Compatible Part Numbers: XL-2400, XL2400, XL-2400U, XL2400U, XL-2400E, XL2400E, F93087500, F-930-8750-0, A1129776A, A-112-9776-A
For Enclosure: Sony Lamp ( XL-2400 / 2-590-738 ).
Television Type: 3LCD.
For Bulb: UHP 120 / 100w 1.0 E 19.8
Philips UHP 120 / 100w 1.0
E 19.8 1.0 Philips.
on Mar 25, 2010 | Televison & Video
XL-2400 lamp replacement.
I have this exact same problem. I even put the old lamp back in to see if it was the new lamp and the same fuzzy orange/redish hue was still there.
Jul 27, 2010 | Sony (XL-2400) Projector Lamp for...
My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
Replace lamp in tv to get problem solved.
Thanks.
Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
How do you install the lamp on a sony wega model
Hi,your part # is xl-2400 here's a video on how to replace it: http://www.youtube.com/watch?v=b31IYV3IYKs The instructions to replace the lamp http://guides.fixyourdlp.com/sony/XL-2400.php and where to find it : http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm
Feb 10, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Nov 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the XL-2400 complete bulb replacement now I have a pink hue at the top of my screen and green hue at bottom of my tv screen
I change the lamp 4 my tv sony vega XL-2400 and I steel send me a signal to change the lamp what can I do 4 setup.
Oct 05, 2009 | Sony Office Equipment & Supplies
How do i install a replacement xl 2400 lamp within a housing unit into my sony wega kdf46e2000 tv??????
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Sep 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10
You may want to have the optical block checked out. Usually when you see spots or blotches of color it's due to a malfunction of the Opt. Block assembly.
Feb 22, 2008 | Sony (XL-2400) Projector Lamp for...
Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10 Logo
79 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
