Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner faulty how can i disable the scanner so that i can continue using the printer
  • 21 Answers
You can't, this is a famous problem on all of these HP machines, however, its relatively easy to solve: you need t remove the keypad, then remove the scanner glass - under the scanner glass is a white strip that need to be cleaned with glass cleaner. You should also clean the mirrors on the scanner assembly. I have repaired about 50 of these machines, both inkjet, laser and scanner only in this way
Posted on May 11, 2008
How to disable the pop up of saying "The paper was not detected. Continue anyway?"
U cant turn off error notifications on these scanners. It could be the firmware version needs to be updated. also the reset instructions are on the support page under know issues. Try if u can using it on another system to see if its a compatiblity issue on this system. Does it continue to scan after error code>
Ill follow this to see. If still issues reply with more info..ie system OS other devices connected like printers or other usb devices.
Good Luck
Chadman
Dec 23, 2013 | Card Scanning Solutions ScanShell 800N...
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
My officeprinter is not scanning
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
click start all programs scroll to HP Officejet you should be able to see your scanner there click on open scanner driver the scanner should open make sure its turned on and that all leads attached 240 volt/USB have a secure seating and are not bad/faulty
hope this helps
Jan 24, 2011 | HP Officejet J3680 Multifunction Printer...
Gettining error 57.03 in hp laserjet 5200 printer
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Dec 22, 2010 | HP Office Equipment & Supplies
Cannot scan documents
ok try disabling the printer the enable it. almost like rebooting the printers drivers... if that dont resolve the issue then try reinstalling the printer incase that some of its drivers has bcome corrupted or uninstalled.
Nov 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
57.03 error
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
Printer Port is used by another device
Just only check and delete error print task queue in all of printers.
Start->settings->printers and faxes.
Right click and open each printer on your machine to find which printer remain error queue and delete it.
Good luck...
sUPERTUYZ
Jun 18, 2006 | Canon CanoScan N340P Flatbed Scanner
HP OfficeJet 6110 All-In-One InkJet Printer Logo
151 people viewed this question
Ben Johnson
