Question about Garden
Looking for the name and type with pictures of the fasteners (hardware) or screw locks that are use assemble the desk
  • 760 Answers
Http://www.refinishfurniture.com/cat_particle_fasteners.htm
Home depot has many fasteners for particle board furniture
Posted on Sep 02, 2010
Testimonial: "That info was end website was right one the money thanks."
Missing assembly directions
It seems they have many models but this may help?
https://www.youtube.com/watch?v=MkX8NvgQK_w
Hope that helps!
Dec 01, 2013 | Ergocraft Furniture
Graco pack play
Hi Carol, remove the fastener from the opposite side of the one that is missing and take it to a Home Depot or Lowes in your neighborhood. Some well stocked hardware stores may also be able to help. They have both metric and standard threaded screws and bolts and I believe the Graco uses metric. They have boards in the hardware department that should tell you which type you need.
It doesn't usually need to look the same to do the job but if they have nothing to help you out, you will at least know if it's standard (for example 10/24 x 1" which means the screw or bolt is size 10 with 24 threads per inch by 1 inch long) or metric (M5 x 0.8 x 1" which is the metric size closest to a 10/24 x 1") and the type of head, hex or bolt head or a screw driver head, Phillips or flat-bladed.
Armed with that information you'll be able to locate the exact replacement from hardware providers on the internet.
(If the head is unusual, take a picture)
Hope this helps,
The Tinker
Nov 30, 2013 | Baby Gear
I have lost the screws, bolts and guides for my christina cotbed. Basically I need to find all the fixing parts to assemble the cotbed. where can I get it from?
Always put fasteners in a zip lock freezer bag and tape it to the furniture. There are professional fastener places where you can match anything if you have samples to bring with you. My city has such a place. But you will never find the hardware without being very mechanical and the end result may not be as safe for a child as the original hardware. Is the safety of your child worth the risk? Or is buying another unit worth a little insurance toward the welfare of your child?
Nov 02, 2013 | Simplicity for Children 8996CRH Crib
What is a threaded fastener?
A threaded fastener is a kind of hardware, the type that has screw threads (inside or out). You use them to assemble or disassemble other parts. For example, the screw or nut.
Jan 31, 2013 | Hardware & Accessories
Looking to see what size screws are used to mount the 26" viewsonic tv to wall bracket. dont know the size or length. Thanks
kits are sold at wal-mart they include spacers and mounting hardware i used allen key hardware from the v-brake mounting assembly of an old mtn bike and it was fine they are also available in bulk from your local fastener depot and would be the budget way to do it ok
Dec 30, 2010 | ViewSonic Televison & Video
Removing and reinstalling a new headlight assembly in a 95 jeep grand cheerokee
LIGHTING Headlights REMOVAL & INSTALLATION Cherokee, Wagoneer and Comanche Models Fig. 1: Remove the top corner headlight bezel mounting screw 91076p12.jpg
Fig. 2: To access the turn signal bulb or headlight bezel mounting screws, remove the 2 turn signal housing retaining screws 91076p13.jpg
Fig. 3: After removing the turn signal housing from the headlight bezel, remove the 2 bezel mounting screws . . . 91076p27.jpg
Fig. 4: . . . then carefully pull the headlight bezel away from the headlight assembly 91076p11.jpg
Fig. 5: Remove the 4 headlight assembly retaining ring screws . . . 91076p07.jpg
Fig. 6: . . . then pull the retaining ring off of the headlight assembly 91076p06.jpg
Fig. 7: Pull the headlight assembly away from the vehicle just far enough to disengage the electrical connector from behind the headlight 91076p28.jpg
  1. Remove the headlamp bezel and retaining ring attaching screws. Remove the bezel and retaining ring.
  2. Pull the headlight out, disconnect the wire harness and remove the headlight from the vehicle.
  3. Install the headlight in the reverse order of removal.
Grand Cherokee and Grand Wagoneer Models
  1. Open the hood, reach into the engine compartment and locate the lock ring supporting the bulb assembly.
  2. Rotate the lock ring 1?8 turn counterclockwise and pull the bulb straight out from the housing. To install:
  3. Install a new bulb and position the bulb assembly in the lamp housing.
  4. Rotate the lock ring 1?8 turn clockwise to secure.
The Grand Cherokee will have an assembly that is fastened with bolts and screws to the body.
Get the new assembly and compare to the old one to see where to unfasten the bolts and other fasteners to aid in removing quickly.
Oct 08, 2010 | 1995 Jeep Grand Cherokee
I need to install my cruise control switch on my steering wheel . How do I go about removing the back cover on the steering wheel?
Removal & Installataion
  1. Verify that the multifunction turn signal lever is in the center of the OFF position.
  2. Disconnect the negative battery cable.
  3. Disable the SIR (air bag) system. Refer to the Chassis Electrical Section.
  4. Remove the air bag module from the steering wheel.
  5. Remove the steering wheel.
Exploded view of the shroud-type steering column showing shrouds, wiring and multifunction switch that includes the headlamp function
    1. Remove the upper and lower steering wheel trim covers using the following procedure.
    2. Remove the tilt lever assembly.
    • Remove the two pan head tapping screws from the lower shroud.
    • Unlock the upper and lower shroud.
    • Remove the two Torx® head screws from the upper shroud.
    • Remove the upper shroud.
    1. Remove the wire harness straps from the wire harness assembly and detach the wiring harness connectors from the switch side connectors.
    2. Remove the two multifunction turn signal switch screws and remove the multifunction switch assembly from the vehicle.
    To install:
    1. Install the multifunction switch to the steering column. Use a small flat-blade prytool to compress the electrical contact and move the multifunction turn signal switch into position. Verify that the electrical contact rests on the canceling cam. Install the screws and tighten to 62 inch lbs. (7 Nm).
    2. Route the wire harness along the steering column jacket assembly and secure into the wire harness strap. Install a new wire tie to the upper tilt head assembly and another lower along the wiring harness, as the original installation.
    3. Verify that the lever is in the center of the OFF position.
    4. Install the upper and lower steering column shrouds.
    5. Route the SIR connector through the steering wheel, align the scribe mark on the steering wheel made at removal, with the slash mark on the steering shaft and install the steering wheel. Install the steering shaft nut and torque to 30 ft. lbs. (41 Nm).
    6. Install the horn contact leads and the air bag connector to the back of the air bag. Make sure the CPA wedge is in place to secure the connector. Install the air bag by gently pushing on both the right and left sides of the air bag until the retaining springs engage.
    7. Enable the SIR system by connecting the yellow 2-way connector at the base of the steering column and installing the air bag fuse.
    8. Connect the negative battery cable. Test the horn, turn signals and headlight operation.
    1. Disable the SIR system.
    2. Remove the upper and lower trim covers.
    3. Remove the knee bolster.
      NOTE The abrasion sleeve located on the steering column wire harness assembly must be reinstalled. Make note of what connector is coming out of the abrasion sleeve for installation purposes.
    4. Remove the wire harness assembly from the wire harness strap.
    5. Disconnect the turn signal and multifunction switch assembly connector from the SIR system coil connector.
    6. Slide the 2 connectors of the turn signal and multifunction switch assembly out of the bulkhead connector.
    7. Remove the 2 pan head tapping screws and from the turn signal and multifunction switch assembly.
    8. Remove the turn signal and multifunction switch assembly from the steering column tilt head assembly.
    To install:
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    CAUTION Be sure that the electrical contact of the turn signal and multifunction switch assembly (2) rests on the turn signal cancel cam assembly.
    CAUTION The abrasion sleeve must be installed back onto the steering column wire harness assembly. The ignition lock cylinder case wires and connector must be hanging out of the middle of the abrasion sleeve.
    1. To install, reverse removal procedure.
    2. Tighten the following to specification.
      • Top pan head tapping screw: 27 inch lbs. (3 Nm).
      • Side pan head tapping screw: 62 inch lbs. (7 Nm).
    CAUTION When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Refer to SIR Disabling and Enabling . Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
    Dec 08, 2009 | 2005 Chevrolet Impala
    Screw fitting
    The bed could be assembled a number of way:
    By Lag screws.
    By Screws and Nuts.
    By Quarter turn Fasteners.
    By a Screw and a tapped Cross Pin.
    Take the part to an ACE Hardware or Home Improvement Store for a replacement.
    You will need a wrench to tighten the Fastener. An adjustable wrench would work nicely.
    Sep 03, 2009 | Hand Tools
    Want to replace brake light bulb on a 04 aviator
    OPEN THE LIFT GATE TAKE OUT THE TWO SCREWS ON THE SIDE OF THE TAIL LIGHT LENSE THEN PULL ON THE TAIL LENSE TO RELEASE IT FROM THE SELF LOCKING FASTENERS YOU CAN'T SEE, REPLACE ALL THE BULBS AND REVERSE POROCEDURE.
    Jul 13, 2009 | 2004 Lincoln Aviator
    I have to replace the glove box latch - where can i get directions to do that myself
    My best Guess is This Info Would be Hard if not Impossible to Get. I Would Just Take a GOOD LOOK at it and Search for A Screw or CLIP TYPE FASTENER os Push Pin that Holds it On from the Inside.
    If It Was Here In My Face I am Positive I Could Remove it as I am Familiar with Most All Lock Fastening Methods. Sorry This Is NOT Exactly What You Are Looking for But Hopefully You CAN just Look and Find the Method of Fastening for this Lock.
    Jun 03, 2009 | 2004 Chrysler Concorde
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
