Question about Humminbird Fishfinder 525 406260 1
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
  • 3,519 Answers
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Posted on Dec 04, 2015
2 Suggested Answers
ward_knutson
  • 64 Answers
SOURCE: go about getting operational anual for fish finder humminbird
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
Posted on Nov 26, 2008
I have a Humminbird 708ci hd si fishfinder. I have issues with it turning off when moving at higher speeds on a little choppy water. I have the basic unit mount. What should I try to fix the issue?
Make sure all your wire and contacts are pressed in good, try taking your finder off the mount hold in your hand while going fast, see if it still goes off, if it does you might have a bad fish finder, or transducer is hitting hull or loose wire some where.
Oct 02, 2013 | Boating
I did lost my operation manual for my fishfinder humminbird 570
Hi!
Since your unit isn't listed in their owners manual section, you'll have to contact their support rep.
http://www.humminbird.com/support/Contact_Support.aspx
Hope this helps you out.
Jun 20, 2011 | Humminbird Fishfinder 565 With Transom...
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Sep 04, 2017 | Humminbird Fishfinder 550
Turns off
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
Jun 29, 2010 | Humminbird 161 Gps Fish Finder Combo
CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
Need the directions to wiring the humminbird fish finder piranha max 210
Wiring should be very straightforward, the connector on the left (looking at the back of the sounder) is the plug for the transducer, the 2 pin plug in the middle is for the power (notch in the plug cord points UP), and the 4 pin connector is for the optional speed and/or temperature sensor. Here is an install manual for your reference:
http://www.humminbird.com/PDF/Piranha1_2_IN.pdf
Mar 15, 2009 | Humminbird Fishfinder, Piranhamax 210 Pt...
Humminbird Fishfinder 525 406260 1 Logo
933 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
